[SOLVED] Button Problems
I have a two pin pbs, one pin plugged into PWM 5 (have tried others) and the other to ground. Using Arduino DUE.
const int BUTTON = 5;
  pinMode(BUTTON,INPUT);
  digitalWrite(BUTTON,HIGH);
  if(digitalRead(BUTTON == LOW)){
    Serial.println("Button is depressed!");
This is not Serial.print-ing "Button is depressed" (or anything else), yet the multimeter reads the pin changing voltage when I press the button... Not sure what I'm doing wrong here.
Thank you.
Does pinMode(pin,INPUT); followed by digitalWrite(pin,HIGH) work on the Due the same way that it does on an AVR-based Arduino? I'm not sure it does...
Try doing pinMode(pin,INPUT_PULLUP); as is recommended.
Still doesn't work. But thanks anyways. Any other ideas?
P.S. I said the multimeter was reading correctly.
Try
if(digitalRead(BUTTON) == LOW){
There's the problem. Thank you!
