SOLVED: Can't Communicate with a 9DOF stick
Hello. So in my school we did a workshop to build a little robot (mine's named Oreo), and this robot has 2 motors, an IR sensor, some LEDs, and a Sparkfun motor controller shield. We went through a bunch of stuff to build the robot, but once we got to the end, everyone was tired and the programming for the compass was pretty complicated and a majority of it we just copy-pasted into our code. The compass gave me a heading for a while, but now that I've tried integrating it into how the wheels spin, something isn't working and I'm almost 100% sure it has to do with the compass code.
Here's the code:
void compassSetup(){
  compass.settings.device.commInterface = IMU_MODE_I2C;
  compass.settings.device.mAddress = LSM9DS1_M;
  compass.settings.device.agAddress = LSM9DS1_AG;
  // The above lines will only take effect AFTER calling
  // compass.begin(), which verifies communication with the compass
  // and turns it on.
  if (!compass.begin())
    Serial.println("Failed to communicate with LSM9DS1.");
    Serial.println("Double-check wiring.");
    Serial.println("Default settings in this sketch will " \
                  "work for an out of the box LSM9DS1 " \
                  "Breakout, but may need to be modified " \
                  "if the board jumpers are.");
    while (1)
float getHeading(){
  float x,y;
  // Once you have your heading, you must then add your 'Declination Angle',
  // which is the 'Error' of the magnetic field in your location.
  // Find yours here: http://www.magnetic-declination.com/ Mine is:
  // +8° 29' West, which is 8.483 Degrees, or (which we need) 0.14805628 radians, I will use 8.483
  // degrees since we convert it to Radians later in the code.
  // If you cannot find your Declination, comment out these two lines, your compass will be slightly off
  float declinationAngle = 7.75; //Declination in Boulder, Colorado
  // Calibration parameters for accuracy
  float Xoffset = .31;
  float Yoffset = 0.41;
  float Xscale = 1.18;
  float Yscale = 0.87;
  // Get Magnetic field readings
  compass.readMag();
  // Subtract calculated offsets from magnetometer data
  x = compass.calcMag(compass.mx)-Xoffset;
  y = compass.calcMag(compass.my)-Yoffset;
  // Scaling correction
  x *= Xscale;
  y *= Yscale;
  // Begin to calculate heading
  float heading;
  // Calculate the angle
  if (y == 0)
    heading = (x < 0) ? PI : 0;
    heading = atan2(y,x);
  // Correct for Declination
    heading -= declinationAngle * (PI/180);
  // Correct for sign errors
  if (heading > 2*PI) heading -= (2 * PI);
  else if (heading < -PI) heading += (2 * PI);
  else if (heading < 0) heading += (2 * PI);
  // Convert everything from radians to degrees:
  heading *= (180.0 / PI);
  //Return the heading
  return heading;
  //Serial.print("Heading: "); Serial.println(heading, 2);
When I run it, there's no direct error but the serial port just reads "Can't connect with the LSM9DS1
Here's main tab of the code if something's wrong there:
//Includes all the required libraries
#include <LSM9DS1_Registers.h>
#include <LSM9DS1_Types.h>
#include <Wire.h>
#include <SPI.h>
#include <SparkFunLSM9DS1.h>
//Sets up pins
const int pwm_right = 3;
const int pwm_left =  11;
const int dir_right = 2;
const int dir_left = 4;
const int distance = A3;
//Sets up IR values
int distanceRead = 0;
float distanceVoltage = 0.0;
//Sets up compass
LSM9DS1 compass;
//Sets up addresses for the compass
#define LSM9DS1_M 0x1E
#define LSM9DS1_AG 0x68
//Sets up LED pins
#define BLUE 6
#define GREEN 5
#define RED 9
int redValue;
int greenValue;
int blueValue;
//Sets up the compass heading
float currentHeading = 0;
float goalHeading = 180;
//Runs once before the loop code
  //Sets motor pins as outputs
  pinMode(pwm_right, OUTPUT);
  pinMode(pwm_left, OUTPUT);
  pinMode(dir_right, OUTPUT);
  pinMode(dir_left, OUTPUT);
  pinMode(distance, INPUT);
  //Sets up LED pins as outputs
  pinMode(RED, OUTPUT);
  pinMode(GREEN, OUTPUT);
  pinMode(BLUE, OUTPUT);
  //Defaults LEDs to be off
  digitalWrite(RED, LOW);
  digitalWrite(GREEN, LOW);
  digitalWrite(BLUE, LOW);
  //Starts serialization
  //Defaults the motors to be off
  forward (0,0);
  //Runs the compassSetup code on Compass_Tools
  compassSetup();
//Runs indefinitely forever
  //Sets the heading and prints it
  currentHeading = getHeading();
  Serial.println("");
  Serial.print("Compass: ");
  Serial.print(currentHeading);
  Serial.print("\t");
  //Sets the IR values
  distanceRead = analogRead(distance);
  distanceVoltage = distanceRead*(5.0/1023.0);
  //This is for an RGB LED, you can ignore this if you just have a red LED
  redValue = map(distanceRead, 0, 1024, 0, 255);
  //Again, this is only for my RGB LED.
  //If you have a normal LED, use digitalWrite(Red, HIGH) or whatever
  analogWrite(RED, redValue);
  analogWrite(GREEN, greenValue);
  analogWrite(BLUE, blueValue);
  //If there's an obstacle, stop, if not, go.
  if(distanceVoltage < 2) {
    forward(100, 100);
    forward(0,0);
  if(currentHeading > goalHeading) {
    forward(100, (int)(100-(currentHeading - goalHeading)));
  } else if (currentHeading < goalHeading) {
    forward((int)(100-(goalHeading-currentHeading)), 100);
I know this is a lot, but thanks for the help.
*Edit: Also I know it's a programming issue because the example code for the LSM9DS1 works fine.
Double check your wiring, and run the I2C address scanner program to see if the device is detected.
If not, there is a problem with your wiring or the device itself.
This approach rarely works. Get each part of the project working perfectly, before putting everything together.
I know everything works fine because if I use the example code that we have, it all works fine. Also if I use the example code that comes with the LSM9DS1, it works fine. So I know it's not a wiring issue.
Do the examples work with the Arduino in the robot, with everything else attached? If not, it IS a wiring issue.
Yes. Thats what I mean. I can upload the previous examples right now and they'll all work fine. It's JUST my code.
If the example can communicate with the device, and your code can't, you need to look very carefully at what copy/paste/edit mistakes you made.
Umm... The only thing I changed on the Compass_Tools section is I changed the x/y-offsets and scaling based on a little test we did, along with changing the declination to match my location. But then I just copied and pasted all of it.... OH WAIT!!! I found it!!
I have the connection port thingy set to 0x68 when it should've been 0x6B, it's all working now. :slight_smile: Thanks guys.
Uhh I've never used this forum before, do I have to mark the question as answered or...?
You can edit your original post, and add SOLVED to the title.
Damn them copy/paste bugs anyway.
