Hi. I am trying to send a single byte from a Python TCP socket server to an ESP8266 running a sketch using the Arudino IDE. I've seen a number of posts on serial USB communications, but I am specifically communicating via sockets over WiFi.
Python socket server:
import serial
import socket
import threading
import time
import tkinter as tk
port = 35000
total_points = [0,0,0]
habits = [20,15,10,10,10,10,5,0,-5,-5,-5,-5,0,0,0,0]
class SerialThread(threading.Thread):
def __init__(self):
threading.Thread.__init__(self)
def run(self):
with socket.socket(socket.AF_INET, socket.SOCK_STREAM) as server_socket:
server_socket.bind(('0.0.0.0', port))
server_socket.listen(1)
print("Intialize socket server, listen port: {}".format(port))
while True:
print("Waiting for connection")
conn, address = server_socket.accept()
with conn:
print('Connection: ', address)
while True:
data = conn.recv(1024)
print("Data Received: ", data)
if not data: break
if (data == b'\r\n'): break
points = habits[int(data, base=16)]
total_points[0] = total_points[0] + points
points_bytes = points.to_bytes(1, byteorder = 'big', signed=True)
conn.send(points_bytes)
print("Data Sent: ", points_bytes)
class App(tk.Tk):
def __init__(self):
thread = SerialThread()
thread.start()
app = App()
app.mainloop()
This is great. When the ESP8266 sends a byte (0x00, for example), I get:
Intialize socket server, listen port: 35000
Connection: ('192.168.4.9', 64423)
Data Received: b'0'
Data Sent: b'\x14'
Data Received: b''
On the ESP8266 side, I am using the ESP8266WiFi library to send and receive data which I believe uses the Arduino Stream class under the covers:
#include <ESP8266WiFi.h>
#define MENU_REWARDS 0
#define STASSID "[OMITTED]"
#define STAPSK "[OMITTED]"
#define PIN_SELECT D3
int menuItem = 0;
int whichMenu = MENU_REWARDS;
const char* ssid = STASSID;
const char* password = STAPSK;
const char* host = "192.168.4.1";
const uint16_t port = 35000;
static const byte rewardsByte[] = {
0x00,
0x01,
0x02,
0x03,
0x04,
0x05,
0x06
static const byte penaltiesByte[] = {
0x08,
0x09,
0x0A,
0x0B
bool debug = true;
if(debug) Serial.print("Connecting to ");
if(debug) Serial.println(ssid);
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
if(debug) Serial.print(".");
if(debug) Serial.println("");
if(debug) Serial.println("WiFi connected");
if(debug) Serial.println("IP address: ");
if(debug) Serial.println(WiFi.localIP());
IPAddress ip = WiFi.localIP();
byte getMessageByte(int message) {
return (whichMenu == 0) ? rewardsByte[message] : penaltiesByte[message];
char *printBytes(byte *bytes) {
char bytesStr[10];
sprintf(bytesStr, "%02X", bytes);
if(debug) Serial.print("bytesStr: ");
if(debug) Serial.println(bytesStr);
return bytesStr;
byte *communicateWifi(byte message) {
byte response[10] = {'0x00','0x00','0x00','0x00','0x00','0x00','0x00','0x00','0x00','0x00'};
int bytesRead = 0;
if(debug) Serial.println("Connecting to " + String(host) + ":" + String(port));
WiFiClient client;
if (client.connect(host, port)) {
if(debug) Serial.println("Connection failed!");
if(debug) Serial.println("Sending data to server: " + message);
if (client.connected()) {
client.print(message);
// wait for data to be available
unsigned long timeout = millis();
while (client.available() == 0) {
if (millis() - timeout > 5000) {
if(debug) Serial.println(">>> Client Timeout !");
client.stop();
return response;
if (client.available()) {
int bytesRead = client.readBytes(response, 10);
printBytes(response);
if(debug) Serial.print("bytesRead: ");
if(debug) Serial.println(bytesRead);
else {
Serial.println("Client not available");
// Close the connection
if(debug) Serial.println("Closing connection");
client.stop();
else {
return response;
void processMenu() {
int select = digitalRead(PIN_SELECT);
if(select) {
if(debug) Serial.println("SELECT");
byte message = getMessageByte(menuItem);
//if(debug) Serial.println("Message: " + message);
byte *response = communicateWifi(message);
char *responseStr = printBytes(response);
processMenu();
and here is the response I get:
Connecting to 192.168.4.1:35000
bytesStr: 3FFFFF10
bytesRead: 1
Closing connection
bytesStr: 3FFFFF10
I don't understand why I am not reading the byte correctly on the ESP8266 side. I have tried a number of different combinations of client.readBytes, client.read, converting everything to char * and doing client.readString -- I can't seem to decode the byte on the ESP8266 side.
What am I doing wrong? I want to be getting the b'\x14' that the server is sending (would be even happier with 20!) but instead I am getting 3FFFFF10.
Thanks in advance for any help anyone might be willing to offer!
