[SOLVED] Can't reinstall UNO-dfu_and_usbserial_combined.hex
I was experimenting with the LUFA keyboard example on my Arduino Uno R3 following these instructions.
http://smartinteractionlab.com/lufa-example-turning-your-arduino-into-a-keyboard/
I was able to flash the keyboard firmware but when I try to reflash either the original UNO-dfu_and_usbserial_combined.hex or the keyboard firmware I get the following error.
avrdude: Version 5.11.1, compiled on Oct 30 2011 at 10:37:28
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/etc/avrdude.conf"
         User configuration file is "/home/spearson/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 002:046
         AVR Part                      : AT90USB82
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC6
         RESET disposition             : possible i/o
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no        512    4    128  9000  9000 0x00 0x00
           flash         65     6   128    0 yes      8192  128     64  4500  4500 0x00 0x00
           lfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           lock           0     0     0    0 no          1    0      0  9000  9000 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : USBtiny
         Description     : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
avrdude: initialization failed, rc=-1
avrdude: AVR device initialized and ready to accept instructions
avrdude: Device signature = 0x000000
avrdude: Yikes!  Invalid device signature.
avrdude: Expected signature for AT90USB82 is 1E 93 82
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude done.  Thank you.
The command line I previously used to flash the LUFA firmware now gives the same error.
The command I used to burn the keyboard example is.
avrdude -p at90usb82 -F -P usb -c usbtiny -U flash:w:Arduino-keyboard-0.3.hex -U lfuse:w:0xFF:m -U hfuse:w:0xD9:m -U efuse:w:0xF4:m -U lock:w:0x0F:m -v
The command I am trying to reflash the original firmware is.
avrdude -p at90usb82 -F -P usb -c usbtiny -U flash:w:UNO-dfu_and_usbserial_combined.hex -U lfuse:w:0xFF:m -U hfuse:w:0xD9:m -U efuse:w:0xF4:m -U lock:w:0x0F:m -v
I'm still able to program the arduino using the tinyusb programmer so the programmer and cable seem OK.
The usb keyboard example worked so I'm sure the reflashing worked OK. I just can't get back to the original serial firmware.
Is there anything else I can try or am I stuck with the keyboard firmware?
Try using -p m16u2
This is the proper part type for the ATmega16U2
I get the same error with -u m16u2
avrdude -p m16u2 -P usb -c usbtiny -U flash:w:UNO-dfu_and_usbserial_combined.hex -U lfuse:w:0xFF:m -U hfuse:w:0xD9:m -U efuse:w:0xF4:m -U lock:w:0x0F:m -v -v -v -v -B 32 -F
         Using Port                    : usb
         Setting bit clk period        : 32.0
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 002:010
         AVR Part                      : ATmega16U2
         PAGEL                         : PD7
         BS2                           : PC6
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
           flash         65     6   128    0 yes     16384  128    128  4500  4500 0x00 0x00
avrdude: Setting SCK period to 32 usec
CMD: [ac 53 00 00] [00 00 00 00]
avrdude: Expected signature for ATmega16U2 is 1E 94 89
Are you powering the 16u2 through the programmer? Or, are do you have the USB cable plugged into the Arduino?
Based on the log, it doesn't look like the programmer is able to read anything from the 16u2.
I'm such an idiot.
I plugged the programmer cable into the Arduino the wrong way round.
The notch made it difficult to insert so I "assumed" it plugged in the other way around.
I must have inserted it the correct way around the first time I programmed.
In my terror at seeing the error message I didn't consider turning the cable around until after a good nights sleep.
I've attached a picture of the correct orientation.
Thanks for the help its great to know there are people willing to spend their own time to look into these types of problems.
