Hi
I'm trying to build my own 433Mhz transmission protocol and library (inspired by rcswitch).
I want to achieve a high data rate (thus high pin state change frequency) but when I use digitalWrite, I can't get fast enough pin changes to have a clear signal.
I read here and there that digitalWrite was looking for the register & bit at every call (which is a logical thing) but I wanted to bypass this by searching for them once, storing the data and using them later.
So copied the digitalWrite code, used the searching part in my setTransmitterPin() function and will use the setting part in my transmit() funciton.
However, as I need to turn off pwm for a pin in order to set it to 1, I used turnOffPWM() macro (same as digitalWrite function) but I get the following error :
In member function 'void Radio::setTransmitterPin(int16_t)':
radio.cpp:16: error: 'turnOffPWM' was not declared in this scope
if (timer != NOT_ON_TIMER) turnOffPWM(timer);
exit status 1
Here is the code :
#include "Arduino.h"
#include <EEPROM.h>
#ifndef _radio_h
#define _radio_h
#define pulseLength 30 // microsecs per pulse
#define offsetTolerance 5 // microsecs per pulse
#define modeQuery 0b0
#define modeReply 0b1
#define signPositive 0
#define signNegative 1
#define codeDiscover 1
#define codeRequestConfig 2
#define codeRequestId 3
#define codeRequestSeed 4
class Radio {
public:
typedef struct Pulses {
int16_t high;
int16_t low;
typedef struct Message {
uint16_t source; // 16 bits
uint16_t destination; // 16 bits
uint8_t mode; // 1 bit : 0 query / 1 reply
uint8_t code; // 4 bits : action code
uint8_t sign; // 1 bit : 0 positive / 1 negative
uint16_t value; // 16 bits max
uint16_t seed; // 16 bits
uint16_t hash; // 16 bits
Radio();
void setTransmitterPin(int16_t pin);
void setReceiverPin(int16_t pin);
void send(Message message, byte secured = 1);
static void init();
int8_t isAvailable();
void resetAvailable();
Message getMessage();
private:
Pulses start = {10, 1};
Pulses stop = {10, 1};
Pulses separator = {10, 10};
Pulses one = {3, 1};
Pulses zero = {1, 3};
uint8_t transmitterBit;
uint8_t *transmitterPort;
uint8_t receiverPin;
uint8_t available;
static Message message;
uint16_t neighborNodes[];
uint16_t masterAddress;
uint16_t masterRoute[3];
void requestConfig(uint16_t node);
void transmit(uint16_t value);
void transmit(uint8_t value);
void transmit(Pulses pulses);
static void receive();
static void parseMessage();
static inline unsigned int diff(int16_t A, int16_t B);
#endif
#include "radio.h"
Radio::Radio(){
this->receiverPin = -1;
this->available = 0;
void Radio::setTransmitterPin(int16_t pin){
this->transmitterBit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
if (port == NOT_A_PIN) return;
this->transmitterPort = portOutputRegister(port);
// If the pin that support PWM output, we need to turn it off
// before doing a digital write.
uint8_t timer = digitalPinToTimer(pin);
void Radio::setReceiverPin(int16_t pin){
this->receiverPin = pin;
static void Radio::init(){
void Radio::transmit(uint16_t value){
char position = (sizeof(value) * 8) - 1;
while(!(value & (1 << position))){
position--;
while (position >= 0){
this->transmit(value & (1 << position) ? Radio::one : Radio::zero);
position--;
void Radio::transmit(uint8_t value){
position--;
position--;
void Radio::transmit(Radio::Pulses pulses){
uint8_t oldSREG = SREG;
cli();
*this->transmitterPort |= this->transmitterBit;
delayMicroseconds(pulses.high * pulseLength);
*this->transmitterPort &= ~this->transmitterBit;
SREG = oldSREG;
delayMicroseconds(pulses.low * pulseLength);
void Radio::send(Message message, byte secured = 1){
Radio::transmit(Radio::start);
Radio::transmit(message.source);
Radio::transmit(Radio::separator);
Radio::transmit(message.destination);
Radio::transmit(message.mode);
Radio::transmit(message.code);
Radio::transmit(message.sign);
Radio::transmit(message.value);
Radio::transmit(message.seed);
Radio::transmit(message.hash);
Radio::transmit(Radio::stop);
int8_t Radio::isAvailable(){
return this->available;
void Radio::resetAvailable(){
Radio::Message Radio::getMessage(){
return this->message;
void Radio::requestConfig(uint16_t node){
static void Radio::receive(){
static void Radio::parseMessage(){
static inline unsigned int Radio::diff(int16_t A, int16_t B){
return abs(A - B);
Thanks for reading me
