[SOLVED] Changing LiquidCrystal I2C address at runtime
Hello everyone, please can you tell me if it's possible to set the address of the lcd display at runtime?
I have two display with different adress (0x3F, 0x27) and I would like to set the address in the setup, not in the initialization
LiquidCrystal_I2C lcd(0x3F, 20, 4);
LiquidCrystal_I2C lcd(0x27, 20, 4);
In this way I can read the address from a configuration file and I don't have to change it manually before sending the sketch to arduino.
I've searched in Arduino-LiquidCrystal-I2C-library-master and Newliquidcrystal_1.3.5 but I haven't found the way to do this.
Thanks, Paolo.
LiquidCrystl_I2C *pLCD = NULL;
   // Find the desired address, and store it in a byte variable names addr
   pLCD = new LiquidCrystal_I2C(addr, 20, 4);
Then, wherever you were using "lcd.", use "pLCD=>" insread.
PaulS:
Thanks, I'm no good with pointers, I've tried this sketch
#include <Wire.h>
LiquidCrystal_I2C *pLCD = NULL;
byte lcdAddress = 39;
  // initialize the LCD
  pLCD = new LiquidCrystal_I2C(lcdAddress, 20, 4);
  pLCD => begin();
  // Turn on the blacklight and print a message.
  pLCD => backlight();
  pLCD => print("Hello, world!");
  // Do nothing here...
and I get this errors
Arduino:1.8.5 (Windows 10), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\Maneat\AppData\Local\Temp\arduino_modified_sketch_19280\HelloWorld2.ino: In function 'void setup()':
HelloWorld2:11: error: expected primary-expression before '>' token
pLCD => begin();
HelloWorld2:11: error: 'begin' was not declared in this scope
pLCD => begin();
HelloWorld2:14: error: expected primary-expression before '>' token
HelloWorld2:14: error: 'backlight' was not declared in this scope
HelloWorld2:15: error: expected primary-expression before '>' token
HelloWorld2:15: error: 'print' was not declared in this scope
exit status 1
Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
"Mostra un output dettagliato durante la compilazione"
in "File -> Impostazioni"
Ok simple not => but ->
Sketch tested ok!
#include <Wire.h>
  pLCD -> begin();
  pLCD -> backlight();
  pLCD -> print("Hello, world!");
What fat-fingered idiot suggested =>? 8)
PaulS:
Now you should probably report yourself to the moderator!
Don
