[solved] Changing pins to use a ILI9486
Hello all,
I have a TFT 3.5" en 8BIT that working with a 'Arduino micro' (ATMEGA32U4)
via this lib 3.5inch Arduino Display-UNO - LCD wiki
The arduino is linked to the TFT card with 8BIT using pins 2,3,4,5,6,7,8,9.
It's working well.
Now i want to free the I2C bus.
I2C is using pins 2 and 3:
  • pin 2 -> SDA
  • pin 3 -> SCL
I want to use pins 14 and 15 for the TFT instead of 2 and 3.
I've found this macro that's writing 8bits data:
#define BMASK 0x30
#define CMASK 0x40
#define DMASK 0x93
#define EMASK 0x40
#define write8old(d) {\
        uint8_t dr1 = (d) >> 1, dl1 = (d) << 1;\
 PORTB = (PORTB & ~BMASK) | (((d) & 0x3)<<4);\
 PORTC = (PORTC & ~CMASK) | (dl1 & (0x1<<6));\
 PORTD = (PORTD & ~DMASK) | (dl1 & (0x1<<7)) | (dr1 & (0x1<<1)) | (((d) & (0x1<<3))>>3) | ((d) & (0x1<<4));\
    PORTE = (PORTE & ~EMASK) | (dr1 & (0x1<<6));\
 WR_STROBE;  }
PORTB, PORTC, PORTD, PORTE are used to write directly in the ATMEGA32U4's registers
Via the chipset doc (chapitre 10.4) i've found that each PORT is 8bits and each bit controling a pin.
On this schema with can find the bits number corresponding to a pin.
Then i'va made this table:
that confirm the mask used in the code:
#define BMASK 0x30 //00110000
  #define CMASK 0x40 //01000000
  #define DMASK 0x93 //10010011
  #define EMASK 0x40 //01000000
I've rewrited the method like this to extract variables:
#define write8(d) {\
 uint8_t PB4_5_ = (((d) & 0x3)<<4);\
    uint8_t PC6_ = (dl1 & (0x1<<6));\
 uint8_t PD1_ = (dr1 & (0x1<<1));\
 uint8_t PD0_ = (((d) & (0x1<<3))>>3);\
 uint8_t PD4_ = ((d) & (0x1<<4));\
 uint8_t PD7_ = (dl1 & (0x1<<7));\
 uint8_t PE6_ = (dr1 & (0x1<<6));\
 PORTB = (PORTB & ~BMASK) | PB4_5_;\
 PORTC = (PORTC & ~CMASK) | PC6_;\
 PORTD = (PORTD & ~DMASK) | PD7_ | PD1_ | PD0_ | PD4_;\
    PORTE = (PORTE & ~EMASK) | PE6_;\
 WR_STROBE;  }
and tried to see how the data send to the write method are used on the pins, using a 'd' value of like 'abcdefgh' (8bits)
d = 'abcdefgh'
dl1 = (d) << 1 gives 'bcdefgh0'
dr1 = (d) >> 1 gives 'aabcdefg'
PB4_5 = (((d) & 0x3)<<4)
0x03 << 4 gives 00110000
& abcdefgh
=> 00cd0000
0x01 << 6 gives 01000000
& bcdefgh0
=> 0c000000
0x01 << 1 gives 00000010
& aabcdefg
=> 000000f0
00x01 << 3 gives 00001000
& abcdefgh
gives 0000e000 then >>3
=> 0000000e
0x01 << 4 gives 00010000
& abcdefgh
=> 000d0000
0x01 << 7 gives 10000000
& bcdefgh0
=> b0000000
& aabcdefg
=> 0a000000
finally
PORT B = 00cd0000
PORT C = 0c000000
PORT D = b00d00fe
PORT E = 0a000000
I need to move pin2 (PD1) to pin15 (PB1) and pin3 (PD0) to pin14 (PB3)
the mask are now:
#define BMASK2 0x3A //00111010
#define DMASK2 0x90 //10010000
PD0_ to PB3_ is like moving 'e' to bit 3 of PORTB like 0000e000
then
uint8_t PB3_ = ((d) & (0x1<<3));\
and PD1_ to PB1_ is like moving 'f' to bit 1 of PORTB like 000000f0
then
uint8_t PB1_ = (dr1 & (0x1<<1));\
finally write8 is now:
 PORTB = (PORTB & ~BMASK2) | PB1_ | PB3_ | PB4_5_;\
 PORTD = (PORTD & ~DMASK2) | PD7_  | PD4_;\
 WR_STROBE;  }
But it's not working!
Can you help me to found where i'm wrong please ?[
Install MCUFRIEND_kbv via the IDE Library Manager.
Buy a proper Leonardo.
Plug the Shield into the Leonardo. Everything should work. (the Leo has less Flash than a Uno so you must be careful with big sketches)
The Pro Micro is only a Leonardo without proper headers.
David.
Yes i could change the hardware but i want to try some code because it seems simpler (and it’s less expensive…)
I’ve found an error in my new mapping, then i’ve corrected this:
MISO = pin 14 = PB3 then i’m moving from (pin 2 SDA) PD1 to PB1
SCLK = pin 15 = PB1 then i’m moving from (pin 3 SCL) PD0 to PB3
This is the code i have now, trying only to change the pin 2 (PD1 to PB1) (easier to locate where i’m wrong i think):
// Original
#ifdef USE_ORG
 WR_STROBE;  }
#endif
//Déplacement du pin2 (PD1) vers pin15 (PB1) et pin3 (PD0) vers pin14 (PB3)
#ifdef USE_NEW
  #define BMASK 0x32 //00110010
  #define DMASK 0x91 //10010001
 PORTB = (PORTB & ~BMASK) | PB4_5_ | PB1_ ;\
 PORTD = (PORTD & ~DMASK) | PD7_ | PD0_ | PD4_;\
 WR_STROBE;  }
#endif
But it’s always not working
Write an accurate table for how you want to wire the Shield e.g.
//regular UNO shield on TEENSY++ 2.0 thanks tysonlt
//LCD pins  |D7 |D6 |D5 |D4 |D3 |D2 |D1 |D0 | |RD |WR |RS |CS |RST|
//AVR   pin |PD7|PD6|PD5|PD4|PD3|PD2|PE1|PE0| |PF0|PF1|PF2|PF3|PF4|
or
//UNO shield on BOBUINO
//AVR   pin |PB3|PB2|PB1|PB0|PD3|PD2|PD6|PD5| |PA7|PA6|PA5|PA4|PA3|
or
//regular UNO shield on GRAND CENTRAL M4
//SAMD51 pin |PD21|PD20|PC21|PC20|PC19|PC18|PB2|PB18| |PA2|PA5|PB3|PC0|PC1|
Note that your Pro Micro will not be able to use the SPI bus for a SD card, ...
You have to make compromises when there are not many pins available.
David.
Ok, i've this one for the original working system:
I've made this table from documentation.
Then i've compared to the code and it's in sync.
Then i've made the new one:
david_prentice:
David.
Yes, in the original configuration, the SPI pins are availlable.
I've choose to free the I2C and scrify the SPI because i need I2C extensions and not planned to use the SD card.
But it' seems difficult to find a TFT board like this one without SD card!
Please write in the style that I have illustrated. i.e. so I can copy-paste
And most importantly so that my eyes don't hurt..
oh, ok sorry :frowning:
Original
LCD|D7 |D6 |D5 |D4 |D3 |D2 |D1 |D0
AVR|PE6|PD7|PC6|PD4|PD0|PD1|PB5|PB4
New
AVR|PE6|PD7|PC6|PD4|PB3|PB1|PB5|PB4
avr |PE6                |PD7                 |PC6                 |PD4                 |PB3
    |E 01000000         |D 10000000          |C 01000000          |D 00010000          |B 00001000
    |E 0a000000         |D b0000000          |C 0c000000          |D 000d0000          |B 0000e000
    |(dr1 &  (0x1 << 6))|(dl1 & (0x1 <<7))   |(dl1 & (0x1<<6))    |(d & (0x1<<4))      |(d & (0x1<<3))
avr |PB1                 |PB5                 |PB4
    |B 00000010          |B 00100000          |B 00010000
    |B 000000f0          |B 00g00000          |B 000h0000
    |(dr1 & (0x1<<1))    |((d>>4)&(0x1<<5))   |((d>>4)&(0x1<<4))
with dr1 = (d) >> 1
with dl1 = (d) << 1
I’ve tried that with masks
#define BMASK 0x3A //00111010
#define DMASK 0x90 //10010000
But it’s still not working…
I have edited the MCUFRIEND_shield.h Leonardo conditional block to suit your wiring:
//################################### TOKAZIO on 32U4 ##############################
#elif defined(__AVR_ATmega32U4__) && defined(USE_TOKAZIO)       //
//AVR   pin |PE6|PD7|PC6|PD4|PB3|PB1|PB5|PB4| |PF7|PF6|PF5|PF4|PF1| tokazio
//AVR   pin |PE6|PD7|PC6|PD4|PD0|PD1|PB5|PB4| |PF7|PF6|PF5|PF4|PF1| Leonardo
#define RD_PORT PORTF
#define RD_PIN  7
#define WR_PORT PORTF
#define WR_PIN  6
#define CD_PORT PORTF
#define CD_PIN  5
#define CS_PORT PORTF
#define CS_PIN  4
#define RESET_PORT PORTF
#define RESET_PIN  1
#define BMASK         ((1<<3)|(1<<1)|(1<<5)|(1<<4))
#define CMASK         (1<<6)
#define DMASK         ((1<<7)|(1<<4))
#define EMASK         (1<<6)
static inline                   //hope we use r24
void write_8(uint8_t x)
    PORTB &= ~BMASK;
    PORTC &= ~CMASK;
    PORTD &= ~DMASK;
    PORTE &= ~EMASK;
    PORTB |= (((x) & (3 << 0)) << 4);
    PORTB |= (((x) & (1 << 2)) >> 1);
    PORTB |= (((x) & (1 << 3)) >> 0);
    PORTD |= (((x) & (1 << 4)) << 0);
    PORTC |= (((x) & (1 << 5)) << 1);
    PORTD |= (((x) & (1 << 6)) << 1);
    PORTE |= (((x) & (1 << 7)) >> 1);
#define read_8()      ( ((PINB & (3<<4)) >> 4)\
| ((PINB & (1<<1)) << 1)\
| ((PINB & (1<<3)) << 0)\
| ((PIND & (1<<4)) >> 0)\
| ((PINC & (1<<6)) >> 1)\
| ((PIND & (1<<7)) >> 1)\
| ((PINE & (1<<6)) << 1)\
#define setWriteDir() { DDRB |=  BMASK; DDRC |=  CMASK; DDRD |=  DMASK; DDRE |=  EMASK;  }
#define setReadDir()  { DDRB &= ~BMASK; DDRC &= ~CMASK; DDRD &= ~DMASK; DDRE &= ~EMASK;  }
#define write8(x)     { write_8(x); WR_STROBE; }
#define write16(x)    { uint8_t h = (x)>>8, l = x; write8(h); write8(l); }
#define READ_8(dst)   { RD_STROBE; dst = read_8(); RD_IDLE; }
#define READ_16(dst)  { uint8_t hi; READ_8(hi); READ_8(dst); dst |= (hi << 8); }
#define PIN_LOW(p, b)        (p) &= ~(1<<(b))
#define PIN_HIGH(p, b)       (p) |= (1<<(b))
#define PIN_OUTPUT(p, b)     *(&p-1) |= (1<<(b))
Obviously untested. I have not even looked at how or when LCDWIKI hacked my library code.
You can see which 6 lines were changed
Obviously untested. Please let me know how you get on.
It is a bit fiddly to write the macros from scratch.
The Leonardo has really awkward pins.
However if you are hand-wiring the Pro Micro you could arrange the pins much more efficiently.
David.
After tried each PORT on a LED, i’ve found thant the pin15 (PB1) was not soldered correctly!!!
Thank you for your precious help and for all these explanation.
Now, I know how to directly write to registers, do bit shifting (and what for) and pin/port mapping.
Thanks a lot.
Final code:
 static inline void write_8(uint8_t x){
 PORTB &= ~BMASK;
 PORTC &= ~CMASK;
 PORTD &= ~DMASK;
 PORTE &= ~EMASK;
