[SOLVED] Char variable not availabe in void loop(); Base64 library
Hello,
Can someone please explain to me why the variable encodedString is only available in void setup()?
How can i make it available in void loop() ?
Thank you very much.
#include <Base64.h>
  // start serial port at 115200 bps:
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB only
  // encoding
  char inputString[] = "Base64example";
  int inputStringLength = sizeof(inputString);
  Serial.print("Input string is:\t");
  Serial.println(inputString);
  int encodedLength = Base64.encodedLength(inputStringLength);
  char encodedString[encodedLength];
  Base64.encode(encodedString, inputString, inputStringLength-1);
  Serial.print("Encoded string is:\t");
  //Serial.println(encodedString);
It’s a scope issue.
A variable defined in a function is not visible in another function.
Move it outside both functions, to make it global.
When i move the code lines outside the void setup() function, i get the following error:
exit status 1
array bound is not an integer constant before ‘]’ token
#include <Base64.h>
 char inputString[] = "  Base64example 123";
  while (!Serial) {
  // encoding
When you declare an array the length must be a constant.
How can i use the value of encodedString in the void loop() function?
Thank you.
Your program has to successfully compile, and it won't until you follow the advice in reply #3.
I have tryied doing the following but i still get the same error message.
exit status 1
#include <Base64.h>
  char inputString[] = "Base64example 123";
  const int inputStringLength = sizeof(inputString);
  const int encodedLength = Base64.encodedLength(inputStringLength);
  while (!Serial) {
  // encoding
You are mixing the varaible declaration and the code.
Serial.print isn’t going to compile outside of a function.
Don’t be tempted to use sizeof to get the length of a string, use strlen.
Thank you for your help.
I understand that Serial.print() does not work outside of a function.
However even using strlen i get the error message:
exit status 1
#include <Base64.h>
  const int inputStringLength = strlen(inputString);
Did that initial code compile correctly?
The reason I ask is that it seems to defy the rule "When you declare an array the length must be a constant." given in post 3 as encodedLength is calculated on the fly?
paulie_iwin:
Neither does Base64.encode
countrypaul:
The initial code is the following and it compiles correctly. I think i have failed to publish this in post #1. :frowning:
I see that with strlen i do not need to add -1 to inputStringLength.
Thank you for the tip!
#include <Base64.h>
  while (!Serial) {
  // encoding
  char inputString[] = "Base64EncodeExample";
  Base64.encode(encodedString, inputString, inputStringLength);
Hello again,
I made it work by placing the code inside a String function.
#include <Base64.h>
String myString()
  // encoding
  return(encodedString);
String myEncode = myString();
Serial.println(myEncode);
paulie_iwin:
Thank you.
Define your global as..
char* myString;   // Globally you create just a char pointer..
void setup(void) {
   ... // bla bla bla
   int caculatedStringLength = something..  // Now you know how big it must be, so..
   myString = (char*) malloc(caculatedStringLength+1);   // Give an extra byte for the'\0'
The pointer was defined as a global, so you can access it the same as a regular global. AND it acts exactly the same as the array of chars that you wanted in the first place.
-jim lee
String myString()
  // encoding
You should never return a pointer to a local variable in a function. Once the function exits that memory can get written over.
ToddL1962:
You should never return a pointer to a local non-static variable in a function. Once the function exits that memory can get written over.
TheMemberFormerlyKnownAsAWOL:
Doesn't appear to be solved...but whatever. LOL
ToddL1962:
String myString()
 // encoding
 char inputString = “Base64EncodeExample”;
That function returns a String object, not a pointer to an automatic variable. The encodedString array is converted to a String in the return statement.
Question for OP: doesn’t encodedString need to be null-terminated? That means it needs to be encodedLength+1 chars long, not just encodedLength chars long (unless Base64.encodedLength() already adds 1 for you).
christop:
Question for OP: doesn't encodedString need to be null-terminated? That means it needs to be encodedLength+1 chars long, not just encodedLength chars long (unless Base64.encodedLength() already adds 1 for you).
Subtle point and well-taken. encodedString is a pointer to the dynamically created encodedString array, but I suppose it is copied into the string object before it goes out of scope. However, I suspect given the apparent skill of the OP it was a fortunate coincidence it works. Had the return type been a char * it would have been a coding error.
