Hello again,
The Subject says it all:
You can find below an example code that gets a char substring from a char string - without using String (with capital S).
- What’s the difference between & and *? They both seem to give a variable’s position in memory.
- I can’t get sizeof() to return the proper size when I’m passing variables as pointers to a function. How to overcome that? (for buffer overrun prevention)
- I’m hoping that any of you know a built-in method that can perform this task in 3 or 4 steps
This is the output:
-sketch started-
ATBuff size: 200
result size: 24
ATBuff position in memory: 978String:
this is my string “and this is what i want”, ignore the reststart (memory position | array position): 997 | 19
end (memory position | array position): 1020 | 42
length: 23
and this is what i wantString:
this is my string “and this is what i want to get”, ignore the reststart (memory position | array position): 997 | 19
end (memory position | array position): 1027 | 49
length: 30
result: can’t store result string (too long)String:
200-byte long with trailing double-quote12345678901234567(…)"start (memory position | array position): 1177 | 199
result: can’t find leading delimiter, or is last char
And this is the code:
char ATBuff[200];
char result[24];
Serial.println("");
Serial.println("-sketch started-");
Serial.print("ATBuff[] size: ");
Serial.println(sizeof(ATBuff)/sizeof(*ATBuff));
Serial.print("result[] size: ");
Serial.println(sizeof(result)/sizeof(*result));
Serial.print("ATBuff position in memory: ");
Serial.println(int(&ATBuff[0]));
Serial.println("------------------------------");
strcpy(ATBuff, "this is my string \"and this is what i want\", ignore the rest");
Serial.println("String:");
Serial.println(ATBuff);
Serial.println("");
get_substring(ATBuff, '"', result);
strcpy(ATBuff, "this is my string \"and this is what i want to get\", ignore the rest");
Serial.println("");
strcpy(ATBuff, "200-byte long with trailing double-quote" // 40 chars
"12345678901234567890123456789012345678901234567890" // 50 chars
"1234567890123456789012345678901234567890123456789012345678\"");
Serial.println("");
// stop sketch
while (true){
delay(100);
void get_substring(char* input_string, char delimiter, char* result_string)
// get the leading delimiter
int sender_start = strchr(input_string, delimiter) - input_string + 1;
Serial.print("start (memory position | array position): ");
Serial.print(int(&input_string[0]) + sender_start);
Serial.print(" | ");
Serial.println(sender_start);
if (sender_start > -1 && sender_start < 199)
// i wanted to use < sizeof(input_string)/sizeof(*input_string)-1 instead
{ // >= 0 --> the delimiter was found and we have its position within the array
// if > arraylength-2, then it's the last char, so we have no possible result.
// (also works as overflow protection)
// get the trailing delimiter
int sender_length = strchr(&input_string[sender_start], delimiter) - input_string - sender_start;
Serial.print("end (memory position | array position): ");
Serial.print(int(&input_string[0]) + sender_start + sender_length);
Serial.println(sender_start + sender_length);
Serial.print("length: ");
Serial.println(sender_length);
if (sender_length > 0) // if < 0, no trailing char "
{ // if == 0, result string is empty
if (sender_length < 24) // overflow protection
// i wanted to use < sizeof(result_string)/sizeof(*result_string) instead
strncpy(result_string, &input_string[sender_start], sender_length);
result_string[sender_length] = '\0';
Serial.println(result_string);
result_string[0] = '\0';
Serial.println("result: can't store result string (too long)");
Serial.println("result: can't find trailing delimiter, or result string empty");
Serial.println("result: can't find leading delimiter, or is last char");
return;
You realize how much code this involves and the conditions I had to place in order to prevent overflows and unexpected return values…
Thanks in advance for reading.
