[SOLVED]class member of derived class does not name a type
Hello, I am used to us derived classes like this for a while but I just do not understand where this error comes from:
Animation.h, parent class:
#ifndef ANIMATION_H
#define ANIMATION_H
#include "Arduino.h"
#include "utilities.h"
class animation
public:
	animation() {}
	void init (utilities * u) { utils = u; }
	virtual void render() = 0;
	int wait;  //These
	int step;  //are
	int duration;  //the problem
	RGB24B colorone;  //and this one
	utilities * utils;
#endif
Test.h:
#ifndef TEST_H
#define TEST_H
#include "animation.h"
class test : public animation
public:
	test(int w)
		wait = w;
		utils->clearLEDs(true);
		for (int i = 0; i < utils->numLeds; i++)
			utils->setLED(i, 255, 255, 255);
			utils->setLED(i - 1, 0, 0, 0);
			utils->show();
			if (utils->checkdelay(wait))
				return;
	wait = 20;  //Throws error
#endif
error:
Test.h: 27:2: error: 'wait' does not name a type
Error compiling project sources
   wait = 20
I just do not understand, why this is a problem… Accessing the inherited utilities pointer works just fine.
wait = 20;
Is that supposed to be an assignment or a definition / initialization?
If the former, it's not inside a function.
If the latter, then you must supply a type for the variable 'wait' (in which case it will shadow the variable of the same name in the base class).
gfvalvo:
wait = 20;
If the former, it’s not inside a function.
If the latter, then you must supply a type for the variable ‘wait’ (in which case it will shadow the variable of the same name in the base class).
Ah right, Thank You. Makes sense. It is supposed to be the first.
