I have two Arduino Ethernets that I need to speak with each other.
Unit 1, the server, is the user interface. It will be connected to a buzzer, LEDs, and some buttons.
Unit 2, the client, detects the state of some equipment and notifies the server of the equipment's status. Depending on the user input from the buttons on the server it will also need to send an output to reset the equipment. (There will actually be two of these, but I will start with 1:1 programming and then adapt for 1:2.)
I need to know:
How to establish the connection between the two devices (and automatically re-establish the connection if it is lost)
How to send/read commands between devices. These devices will only ever speak with each other, so binary or hex commands is fine.
if you look at the Ethernet examples, you have both a server and client sketches. If you connect the client to the servers IP address, you're good to go.
You can check the connection status with the connected() method.
I was actually more interested in how to (efficiently) transfer data between the two devices. All the examples are geared towards the Controller<->Human interface (such as displaying info on a browser).
Do I just need to use .write() on the transmitter and .read() on the the reciever, or is there a better way of doing it?
Ok, so I'm trying to make the "Fade" example work across two boards over an ethernet connection. One board will do the math to calculate and send the value, the other board will recieve the value and do an analogWrite to it's LED.
I'm not 100% sure but it would seem that the units are not establishing a connection [LED 9 is not turning on after boot]. Can anyone offer input as to why that is?
Device 1
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xF5, 0xB2 };
IPAddress ip(10,0,5,121);
IPAddress subnet(255, 255, 252, 0);
int led = 9;
byte brightness = 0; // how bright the LED is
byte fadeAmount = 5; // how many points to fade the LED by
IPAddress server(10,0,5,120); // CCSO Controller Unit
// Initialize the Ethernet client library
// with the IP address and port of the server
EthernetClient client;
pinMode(led, OUTPUT);
client.connect(server, 80);
if(client.connected()){
digitalWrite(led, HIGH);
else{
digitalWrite(led,LOW);
client.write(brightness);
// change the brightness for next time through the loop:
brightness = brightness + fadeAmount;
// reverse the direction of the fading at the ends of the fade:
if (brightness == 0 || brightness == 255) {
fadeAmount = -fadeAmount ;
// wait for 30 milliseconds to see the dimming effect
delay(100);
Device 2
#include <SPI.h>
byte mac[] = { 0x90, 0xA2, 0xDA, 0x00, 0xF5, 0x98 };
IPAddress ip(10,0,5,120);
int led = 9;
EthernetServer server = EthernetServer(80);
Ethernet.begin(mac, ip, subnet);
server.begin();
// wait for a new client:
if (client == true) {
analogWrite(led, client.read());
Could the problem have anything to do with my ethernet.begin order?
Since I'm on a private network, I have no need for a dns or gateway; however I'm on an usual subnet. Do I need to include the dns and gateway in the Ethernet.begin sequence?
Update. I have my server working in an acceptable (though probably not opitimal) fashion. The code is below:
Server:
#include <SPI.h>
int led = 9;
String readString;
server.begin();
if (client) {
while (client.connected()) {
if (client.available()) {
char c = client.read();
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString += c;
//Serial.print(c);
//if HTTP request has ended
if (c == '\n') {
client.println("HTTP/1.1 200 OK"); //send new page
client.println("Content-Type: text/html");
client.println();
client.println("<HTML>");
client.println("<HEAD>");
client.println("<TITLE>Arduino GET test page</TITLE>");
client.println("</HEAD>");
client.println("<BODY>");
client.println("<H1>Arduino Audio Server is Working</H1>");
client.println("</BODY>");
client.println("</HTML>");
delay(1);
//stopping client
client.stop();
if(readString.indexOf("on") >0)//checks for on
if(readString.indexOf("off") >0)//checks for on
digitalWrite(led, LOW);
} //End c == '\n')
} //End if(client.available)
} //End While Client Connected
} //End if(client)
} //End Loop
The long and short of it is from a browser I can do the following:
10.0.5.120 [displays webpage]
10.0.5.120/?on [turns LED on]
10.0.5.120/?off [turns LED off]
However my remote unit is getting stuck on the client.connect line. Is it wanting the server to send it back some information?
What do I need to do on my remote to have it send simple http commands?
#include <SPI.h>
int led = 9;
Serial.println("connecting...");
Serial.println("connected, sending");
client.println("10.0.5.120/?on");
//loop code
