[SOLVED] Clock alarm test/lesson using Timealarms.h, very strange behavior
I’m testing a simple clock with alarm output, based on this post discussing timealarms http://arduino.cc/forum/index.php/topic,37693.0.html .
My question is, when the sketch is uploaded with the current time, the time displayed is not what is hard coded. For example, using setTime(9,07,0,03,22,13); results in the correct time, but the date is displayed as 04/06/2014. Earlier today in the 7 AM hour, the month was 5 and year was 2015.
I do get my expected alarm output at the set time.
Code follows:
//This sketch  triggers a daily alarm output
#include <Wire.h>
#include <Time.h>
#include <TimeAlarms.h>
LiquidCrystal_I2C lcd(0x27,20,4);
void setup() // the setTime results in  8:56:00  4/06/2014
  setTime(8,56,0,3,22,13); // set time to 8:56:00 am Mar 22 2013
  // create the alarms
  Alarm.alarmRepeat(8,45,0, MorningAlarm);  // every morning
  lcd.init();
  lcd.backlight();
  lcd.setCursor(0, 0);
  pinMode(13, OUTPUT);
void  loop(){
  digitalClockDisplay();
  Alarm.delay(1000); // wait one second between clock display
// functions to be called when an alarm triggers:
void MorningAlarm(){
  digitalWrite(13, HIGH);  //alarm test output
  delay(5000);
  digitalWrite(13, LOW);
void digitalClockDisplay()
char buf[19];
  sprintf(buf, "%02d:%02d:%02d %02d/%02d/%4d", hour(), minute(), second(), month(), day(), year());
  lcd.print(buf);
  lcd.setCursor(0,0);
Any suggestions appreciated.
  setTime(8,56,0,3,22,13); // set time to 8:29:00am Jan 1 2010
No, it doesn’t. Comments that are obvious, and wrong, look stupid. I suggest that you get rid of it.
char buf[19];
2+1+2+1+2+1+2+1+2+1+4+1 is not 19. Stuffing 20 characters into a 19 element array will cause problems.
No, it doesn't. Comments that are obvious, and wrong, look stupid. I suggest that you get rid of it.
Comments corrected. Buffer size corrected.
Same results 04/06/2014 from input of setTime(9,07,0,03,22,13);
hours, minutes, seconds, day, month, year is the order of arguments to set time. Today is 22, 3, 13 in that order.
Terrific! Thanks Paul.
That solved it. Thanks for your time.
