[SOLVED]Compilation error: 'lcd' was not declared in this scope
I got this error this morning after adding a sub to my code:
#include <Wire.h>
char inChar;     // Where to store the character read
byte index = 0;  // Index into array; where to store the character
char *AXpos;
char *EYpos;
const char *delimiter = ",";
const byte numChars = 15;
const long _maxRotorAX = 18000L;  // maximum rotor azimuth in degrees * 100
const long _maxRotorEY = 18000L;  // maximum rotor elevation in degrees * 100
char inData[numChars];  // an array to store the received data
boolean newData = false;
  LiquidCrystal_I2C lcd(0x27, 20, 4);  // set the LCD address to 0x27 for a 16 chars and 2 line display
  lcd.init();  // initialize the lcd
  lcd.init();
  // Print a message to the LCD.
  lcd.backlight();
  lcd.setCursor(0, 0);
  lcd.print("XtTrm Ready for data");
  lcd.setCursor(2, 1);
  lcd.print("     XY-Antenna");
  lcd.setCursor(0, 2);
  lcd.print("Arduino LCM IIC 2004");
  lcd.setCursor(1, 3);
  lcd.print("(c)Harry H. Arends");
  Serial.println("XtTrm Ready");
  recvWithEndMarker();
  processNewData();
  extractData();
  updateDisplay();
void recvWithEndMarker() {
  static byte ndx = 0;
  char endMarker = '\n';
  char rc;
  while (Serial.available() > 0 && newData == false) {
    rc = Serial.read();
    if (rc != endMarker) {
      inData[ndx] = rc;
      ndx++;
      if (ndx >= numChars) {
        ndx = numChars - 1;
      //Serial.print(ndx);
      //Serial.print("-");
      //Serial.print("Received= ");
      //Serial.println(inData);
      //Serial.println("Done");
      inData[ndx] = '\0';  // terminate the string
      ndx = 0;
      newData = true;
    //Serial.println(ndx);
void processNewData() {
  if (newData == true) {
    //Serial.println();//terminate starsline
    //Serial.print("This came just in ... ");
    //    newData = false;
    //Serial.print("*");//max.14 stars
void extractData() {
  //Extract two numbers from received data
    AXpos = strtok(inData, delimiter);
    EYpos = strtok(NULL, delimiter);
    Serial.print("AX= ");
    Serial.println(AXpos);
    Serial.print("EY= ");
    Serial.println(EYpos);
    newData = false;
    inData[0] = '\0';  // clear the string
void updateDisplay() {
  // Clear used rows
  //         12345678901234567890
  lcd.print("                    ");
  lcd.setCursor(0, 3);
  lcd.print("                    ");
at the bottom I added a routine to populate my 2004LCD,
If I comment out the lcd lines I wont get a error, so what did I mis??
The lcd object is created in setup() so will not be available anywhere else in the sketch. Move this line of code outside of a function to make the lcd object available globally
Thnx Ooo stupid me
