[solved] compiler error : undefined reference to 'n'
in inline assembly , this specific macro causes the error :
__asm__ __volatile__ (
".macro delay4 n\n\t"
"ldi r17,0\n\t"
"0:\n\t"
"inc r17\n\t"
"cpi r17,n\n\t"
"brne 0b\n\t"
"nop\n\t"
".endm\n\t"
error : undefined reference to 'n' , the argument of the macro
You left the semicolon off the end, but otherwise your macro compiles fine for me. (UNO, IDE v1.6.5):-
"ldi r17,0\n\t"
"0:\n\t"
"inc r17\n\t"
"cpi r17,n\n\t"
"brne 0b\n\t"
"nop\n\t"
".endm\n\t"
Sketch uses 450 bytes (1%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
the semicolon was present in my main program , you must use the delay macro though
and i did get an error out of that
this one gives me "undefined reference to r17"
".macro md_6c\n\t"
"ldi r18,r17\n\t"
"lsr r18\n\t" "lsr r18\n\t" "lsr r18\n\t"
"ldi r19,r17\n\t"
"sub r19,r18\n\t"
".endm\n\t"
Perhaps you should post your whole code?
there you go :
/* r16 - reserved       */
/* r17 - line           */
/* r18 - div/h          */
/* r19 - modulo         */
/* r20 - value          */
/* r21 - addr add lo    */
/* r22 - addr add hi    */
/* r23 - all purpose    */
/* r24 - output         */
// Y
/* r28 - ptr addr low  */
/* r29 - ptr addr high */
// Z
/* r30 - prg addr low  */
/* r31 - prg addr high */
//X
// r26 - main prg addr high
// r27 - main prd addr low
__asm__ __volatile (
".macro shift_28c\n\t"
"out (_SFR_IO_ADDR(PORTC)),r24\n\t" "lsl r24\n\t" "movw r30,r26\n\t" //might cause an error
"out (_SFR_IO_ADDR(PORTC)),r24\n\t" "lsl r24\n\t" "LD r20,Y+\n\t"
"out (_SFR_IO_ADDR(PORTC)),r24\n\t" "lsl r24\n\t" "ldi r23,8\n\t"
"out (_SFR_IO_ADDR(PORTC)),r24\n\t" "lsl r24\n\t" "mul r20,r23\n\t"
"out (_SFR_IO_ADDR(PORTC)),r24\n\t" "lsl r24\n\t" "add r0,8\n\t"
"out (_SFR_IO_ADDR(PORTC)),r24\n\t" "lsl r24\n\t" "adc r1,0\n\t"
"out (_SFR_IO_ADDR(PORTC)),r24\n\t" "lsl r24\n\t" "add r30,r0\n\t" "adc r31,r1\n\t"
"out (_SFR_IO_ADDR(PORTC)),r24\n\t"               "lpm r24,Z\n\t"
".endm\n\t"
".macro scan_line_m7c\n\t"
"h_sync\n\t"
"sync_1\n\t"
"delay4 136\n\t" "nop\n\t"
"delay4 160\n\t"
".endm\n\t"
".macro display_line_m7c\n\t"
"h_sync\n\t"
"sync_1\n\t"        //5.7us = 114c
"delay4 23\n\t" "nop\n\t" "nop\n\t"
//19c total
"md_6c\n\t"
//"ldi r30,r26\n\t"
//"ldi r31,r27\n\t"     //13c
"LD r20,Y+\n\t"
"ldi r23,8\n\t"
"mul r20,r23\n\t"
"add r0,8\n\t"
"adc r1,0\n\t"
"add r30,r0\n\t"
"adc r31,r1\n\t"
"lpm r24,Z\n\t"     //13c
////////////////////////////////////////// 37 shifts  1036c
/*"shift_28c\n\t" "shift_28c\n\t"
"shift_28c\n\t" */
"data_0\n\t" "nop\n\t" "nop\n\t"
"delay4 6\n\t" "nop\n\t" "nop\n\t"
".endm\n\t"
".macro delay4 arg\n\t"
/*"ldi r25,arg\n\t"
"ldi r16,0\n\t"
"0:\n\t"
"inc r16\n\t"
"cpi r16,r25\n\t"
"brne 0b\n\t"
"nop\n\t"*/
".endm\n\t"
".macro md_6c\n\t"
"ldi r18,r17\n\t"
"ldi r19,r17\n\t"
"sub r19,r18\n\t"
".endm\n\t"
".macro sync_0\n\t"
//"cbi %[portb],0\n\t"
".endm\n\t"
".macro sync_1\n\t"
//"sbi %[portb],0\n\t"
".endm\n\t"
".macro data_0\n\t"
//"cbi %[portc],0\n\t"
".endm\n\t"
".macro data_1\n\t"
//"sbi %[portc],0\n\t"
".endm\n\t"
".macro h_sync\n\t"
"sync_0\n\t"
".endm\n\t"
".macro half_short\n\t"
"sync_0\n\t"
"delay4 11\n\t" "nop\n\t" "nop\n\t"
"sync_1\n\t"
"delay4 148\n\t"
".endm\n\t"
".macro half_broad\n\t"
"sync_0\n\t"
"sync_1\n\t"
".endm\n\t"
".macro short_line\n\t" "half_short\n\t"
                        "half_short\n\t" ".endm\n\t"
".macro broad_line\n\t" "half_broad\n\t"
                        "half_broad\n\t" ".endm\n\t"
//37*30 characters
volatile unsigned char ptr_arr[37*30];
volatile unsigned char font [10];
"main:\n\t"
"broad_line\n\t"
"broad_line\n\t"
"half_broad\n\t"
"half_short\n\t"
"short_line\n\t"
"short_line\n\t"
"ldi r17,0\n\t"
"loop0:\n\t"
"scan_line_m7c\n\t"
"inc r17\n\t"
"cpi r17,32\n\t"
"breq close0\n\t"
"jmp loop0\n\t"
"close0:\n\t"
"ldi r17,0\n\t"            //240 lines
"loopa:\n\t"
"display_line_m7c\n\t" //+6c
"inc r17\n\t"
"cpi r17,240\n\t"
"breq close\n\t"
"jmp loopa\n\t"
"close:\n\t"
"ldi r17,0\n\t"
"loop1:scan_line_m7c\n\t"
"inc r17\n\t"
"cpi r17,32\n\t"
"breq close1\n\t"
"jmp loop1\n\t"
"close1:\n\t"
"short_line\n\t"
"short_line\n\t"
"short_line\n\t"
"jmp main\n\t"
:"x" (font),"z" (font),"y" (ptr_arr),[portb] "i" (_SFR_IO_ADDR(PORTB)),[portc] "i" (_SFR_IO_ADDR(PORTC))
:"r17"
I still can't help, it's beyond me, but others will have a better chance now.
Which Arduino are you writing for? That might well be relevant.
i am writing for a 20Mhz UNO
OldSteve : thank you very much for your assistance , i solved the problem
"ldi" should only be used to load constant values into registers it seems ,
so the problem was solved simple by replacing "ldi" with "mov"
and 'n' is a constant , not a register , so it cannot be used with asm commands that require a register + arguments of a macro shoud be noted \n not just n (example for n), that's why the compiler issued a reference problem
thank you again (solved)
Excellent. Glad to hear you solved it. I'm not really that familiar with AVR assembly, my background is more with PICs, (different language/instruction set), so it had me scratching my head.
All's well that ends well. :slight_smile:
