I’ve recently been having a compiling error that I suspect is a fault with the library, and am wondering if anyone else has had this trouble. I noticed this problem only today, when trying to compile a sketch I’ve been working on. I tried an older test sketch (attached) that I know works from previously, and received the same error:
Arduino: 1.8.9 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Build options changed, rebuilding all
D:\allen\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp: In member function 'void Adafruit_TFTLCD::init()':
D:\allen\Documents\Arduino\libraries\TFTLCD-Library-master\Adafruit_TFTLCD.cpp:115:3: error: 'textsize' was not declared in this scope
textsize = 1;
exit status 1
Error compiling for board Arduino/Genuino Mega or Mega 2560.
option enabled in File -> Preferences.
It all seems to relate to the TFTLCD library:
which had been working previously. I’ve tried reinstalling the library, but with no success.
The screen I’m using is an Elegoo 2.8 TFTLCD touch screen. It comes with it’s own library in the provided CD, but as another user pointed out, it’s just the Adafruit library with some name changes. I changed my sketch back to use the Elegoo library instead, and it worked. The sketch was working just fine with the Adafruit library, and nothing in that regard was changed to the sketch. Is this a library issue, or something with my code?
Thank you for any help.
dash_02.ino (9.59 KB)
