Hi.
I'm new to the world of Arduino and electronics. I'm only getting started and as the first project I would like to control the brightness of an LED using an IR remote control that was included in my starter kit, but I have 2 problems.
I got the remote setup and working, no problem with that. I do receive the input from the remote.
The first problem is that however, when I use the analogWrite() function in my code to control the brightness of the LED, for some reason I get a different value from the remote every single time I press the same button, therefore I have no way to tell if I have pressed the correct button on the remote. If I comment out the analogWrite() code and I do nothing with the leds, I get the same value from the remote each time I press the same button but when I have the code un-commented, I get different values for some reason.
On the above image as you can see I am pressing the same button on the remote but I get a different value each time.
The second problem is that if I'm working with more than 1 LED and I have analogWrite() twice in my code, everything just freeze, after 2 attempts, I get no input from the remote any more.
Using Arduino Uno R3 and the IRremote library.
This is my code:
#include <IRremote.h>
const int ledRedPin = 10;
const int ledYellowPin = 9;
const int irReceiverPin = 11;
const long plusButton = 16754775;
const long minusButton = 16769055;
IRrecv iRrecever(irReceiverPin);
decode_results iRInput;
int ledRStr;
int ledYStr;
iRrecever.enableIRIn();
ledRStr = 0;
ledYStr = 0;
if (iRrecever.decode(&iRInput)) {
//if plus button is pressed
if(iRInput.value == plusButton)
ledRStr += 1;
ledYStr += 1;
//if minus buttons is pressed
if(iRInput.value == minusButton)
ledRStr -= 1;
ledYStr -= 1;
Serial.println("IRInput value: " + String(iRInput.value));
Serial.println("Led Strength: " + String(ledRStr));
iRrecever.resume();
//update leds
analogWrite(ledRedPin, ledRStr);
analogWrite(ledYellowPin, ledYStr);
delay(100);
Because I am new to Arduino and electronics, I have no idea why is this happening, I'm totally lost.
I was searching the forum and internet for examples of controlling LED brightness with remote but every single example I find is using digitalWrite() to simply turn the LED on and off but this is not what I want, I want to control the brightness.
In case it is a bug in the library I'm using (IRremote), is there any other libs I could use or is there any workaround exist?
I would appreciate any help or explanation why is this not working for me.
Thank you.
