floresta:
Well, i looked it up and i think that the guy has problem with backlight.
Did you look at reply #6 in that thread?
Don
I did read this post and i tried out your idea. Code here:
/* YourDuino.com Example Software Sketch
20 character 4 line I2C Display
Backpack Interface labelled "LCM1602 IIC A0 A1 A2"
terry@yourduino.com */
/*-----( Import needed libraries )-----*/
#include <Wire.h> // Comes with Arduino IDE
// Get the LCD I2C Library here:
// https://bitbucket.org/fmalpartida/new-liquidcrystal/downloads
// Move any other LCD libraries to another folder or delete them
// See Library "Docs" folder for possible commands etc.
/*-----( Declare Constants )-----*/
//none
/*-----( Declare objects )-----*/
// set the LCD address to 0x20 for a 20 chars 4 line display
// Set the pins on the I2C chip used for LCD connections:
// addr, en,rw,rs,d4,d5,d6,d7,bl,blpol
LiquidCrystal_I2C lcd(0x27, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
/*-----( Declare Variables )-----*/
//none
void setup() /*----( SETUP: RUNS ONCE )----*/
Serial.begin(9600); // Used to type in characters
lcd.begin(20,4); // initialize the lcd for 20 chars 4 lines and turn on backlight
// ------- Quick 3 blinks of backlight -------------
for(int i = 0; i< 3; i++)
lcd.backlight();
delay(250);
lcd.noBacklight();
delay(250);
lcd.backlight(); // finish with backlight on
//-------- Write characters on the display ----------------
// NOTE: Cursor Position: CHAR, LINE) start at 0
lcd.setCursor(3,0); //Start at character 4 on line 0
lcd.print("Hello, world!");
lcd.setCursor(2,1);
lcd.print("From YourDuino");
lcd.setCursor(0,2);
lcd.print("20 by 4 Line Display");
lcd.setCursor(0,3);
delay(2000);
lcd.print("http://YourDuino.com");
delay(8000);
// Wait and then tell user they can start the Serial Monitor and type in characters to
// Display. (Set Serial Monitor option to "No Line Ending")
lcd.setCursor(0,0); //Start at character 0 on line 0
lcd.print("Start Serial Monitor");
lcd.setCursor(0,1);
lcd.print("Type chars 2 display");
}/*--(end setup )---*/
void loop() /*----( LOOP: RUNS CONSTANTLY )----*/
// when characters arrive over the serial port...
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
}/* --(end main loop )-- */
/* ( THE END ) */
Unfortunatelly error appeared:
Arduino: 1.5.7 (Windows 8), Vývojová deska: "Arduino Due (Programming Port)"
C:\Users\Radovan\SkyDrive\Arduino Moje\libraries\LiquidCrystal\FastIO.cpp: In function 'void fio_shiftOut1(fio_register, fio_bit, uint8_t, boolean)':
C:\Users\Radovan\SkyDrive\Arduino Moje\libraries\LiquidCrystal\FastIO.cpp:214:19: error: '_BV' was not declared in this scope
if(value & _BV(i))
I am using libraries from fmalpartida. While using this library i removed the LiquidCrystal library (original) and LiquidCrystal_I2C library from the directory. Printscreeen of directory is attached.
By the way i installed Arduino 1.5.7.
Did i miss something you told me to try or do? :~
