I’m trying to control servo motors using bluetooth(serial), but I have come across an issue that has had me baffled for hours.
I am using an app called Bluetooth electronics by keuwl, and long story short, the arduino receives a sequence of bytes of the following format on the serial port: @BX111,Y111b! ,Where @ is the start byte, B is a method of telling that this packet contains the data regarding the servos, and the numbers represent the angle of the X and Y servos. The ! is the end byte. I will explain why the b is there in a moment.
On plain sight this is very easy to implement, since we know that if we save the packet to a byte array bytes, bytes[3] to bytes[5] will be the numbers for the angle of the X servo, and bytes[8] to bytes[10] will be the numbers for the Y servo. And then all we need to do is subtract ‘0’ from the following bytes(to convert them from ASCII to decimal, since ‘0’ in ASCII is 48 in decimal) and multiply them by a power of 10 before finally summing them to convert the value into decimal format.
for example, for an input @BX111,Y111b! the angle for the X servo in decimal would be:
X=(bytes[3]-'0')*100+(bytes[4]-'0')*10+(bytes[5]-'0');
However, the problem is that placeholders aren’t used, as in no preceding 0’s are sent. for example the app sends @BX11,Y111b! and not @BX011,Y111b!
Here’s the code that I have come up with so far, it works for some inputs but not others. For instance, if the transmitted X value has 3 digits then the received value becomes 0. I left a comment in the code highlighting where I think the problem is. My current approach was inspired by the following post(look at the code for the state machine):
http://www.gammon.com.au/forum/?id=11425
The packet receive protocol was taken from the following post:
Coming back to why b is in the sequence, its purpose is to tell the code that there are no more number bits since I am using the isdigit() function. (can’t use the end byte as it is removed from the sequence after decoding).
#include <Servo.h>
#define motorA1 3 // Pin 2 of L293
#define motorA2 5 // Pin 7 of L293
#define motorB1 6 // Pin 10 of L293
#define motorB2 9 // Pin 14 of L293
#define startMarker '@'
#define endMarker '!'
#define specialByte 253
#define maxMessage 16
#define baseservopin 4
#define shoulderservopin 7
Servo baseservo,shoulderservo;
int BTin=0;
int maxspeed=0;
byte data[maxMessage];
byte tempBuffer[maxMessage];
byte bytesRecvd = 0;
byte dataRecvCount = 0;
boolean inProgress = false;
boolean allReceived = false;
pinMode(motorA1, OUTPUT);
pinMode(motorA2, OUTPUT);
pinMode(motorB1, OUTPUT);
pinMode(motorB2, OUTPUT);
baseservo.attach(baseservopin);
shoulderservo.attach(shoulderservopin);
/* if(Serial.available()>0){
BTin=Serial.read();
getSerialData();
switch(BTin){
case'L':
analogWrite(motorA1, maxspeed);
digitalWrite(motorA2, 0);
case'M':
analogWrite(motorA2, maxspeed);
digitalWrite(motorA1, 0);
case'R':
analogWrite(motorB1, maxspeed);
digitalWrite(motorB2, 0);
case'N':
analogWrite(motorB2, maxspeed);
digitalWrite(motorB1, 0);
case's':
digitalWrite(motorA2,0);
case't':
digitalWrite(motorB2,0);
case'S':
maxspeed=Serial.parseInt();
if(Serial.read()=='S'){break;}
getSerialData();
processData();
void processData() {
// processes the data that is in data[]
byte n,m;
byte anglex=0,angley=0;
if (allReceived) {
if(data[0]=='B'){
//This is the most crucial part of the code(well I think)
for(n=2;n<5;n++){
if(isdigit(data[n])){
anglex *=10;
anglex +=data[n]-'0';
else{
n +=2;
//Serial.println(n);
for(m=n;m<(n+3);m++){
if(isdigit(data[m])){
angley *=10;
angley +=data[m]-'0';
else{
//Serial.println(anglex);
// Serial.println(angley);
baseservo.write(anglex);
shoulderservo.write(angley);
void getSerialData() {
// Receives data into tempBuffer[]
// saves the number of bytes that the PC said it sent - which will be in tempBuffer[1]
// uses decodeHighBytes() to copy data from tempBuffer to data[]
// the Arduino program will use the data it finds in data[]
if(Serial.available() > 0) {
byte x =Serial.read();
if (x == startMarker) {
byte x = startMarker;
bytesRecvd = 0;
inProgress = true;
// blinkLED(2);
// debugToPC("start received");
if(inProgress) {
tempBuffer[bytesRecvd] = x;
bytesRecvd ++;
if (x == endMarker) {
inProgress = false;
allReceived = true;
// save the number of bytes that were sent
// dataSentNum = tempBuffer[1];
decodeHighBytes();
void decodeHighBytes() {
// copies to data[] only the data bytes i.e. excluding the marker bytes and the count byte
// and converts any bytes of 253 etc into the intended numbers
// Note that bytesRecvd is the total of all the bytes including the markers
dataRecvCount = 0;
for (byte n = 1; n < bytesRecvd - 1 ; n++) { // 2 skips the start marker and the count byte, -1 omits the end marker
byte x = tempBuffer[n];
if (x == specialByte) {
// debugToPC("FoundSpecialByte");
n++;
x = x + tempBuffer[n];
data[dataRecvCount] = x;
dataRecvCount ++;
void blinkLED(byte numBlinks) {
for (byte n = 0; n < numBlinks; n ++) {
digitalWrite(13, HIGH);
delay(200);
digitalWrite(13, LOW);
delay(200);
Thank you for bearing with me, and I greatly appreciate you spending your time and effort to help .
