[SOLVED] Conversion from reading character into 6-digit number not working
Why is this conversion from reading 6 characters into a 6-digit number not working?
IDE 1.8.4, Win10, Mega2560.
To run, enter
p0xxxxxx where xxxxxx are the 6 digits
I am trying to make a limit test where once the value exceeds 230000 decimal, it is assigned the value 230000, to prevent any typos from allowing weird things to happen later on.
Yet if I enter 240000 and above, the calculation of the number goes odd.
byte x;
byte command = 0;
byte moveCommand;
byte goodCommand = 0;
byte goodMotor = 0;
byte motorToMove; // the motor commanded to move
byte charStep[6];
unsigned long goToPosition;
unsigned long maxPosition = 230000; // max extension
unsigned long minPosition = 0; // min retraction
  // Turn on Serial
  Serial.println ("Ready to Go.");
  if (Serial.available() > 1 ) { // read 2 bytes
    // if p/P, #0 to 15, then 6 chars, turn into a # 0 to 230,000
    command = Serial.read(); // u/U = up, d/D = down, s/S = stop, p/P = position
    Serial.print (" loop command ");
    Serial.println (command);
    motorToMove = Serial.read(); // , later convert to 0 to 9 then :(10) ;(11) <(12) =(13) >(14) ?(15) for serial monitor test
    if (( command == 'p' || command == 'P') && (motorToMove >= '0' && motorToMove <= 'F')) {
      // good command, good motor#
      goodCommand = 1;
      goodMotor = 1;
      motorToMove = motorToMove - 48; // ASCII to decimal for 0 to 9
      if (motorToMove > 9) {
        motorToMove = motorToMove - 7; // further ASCII  to decimal for A to F
      Serial.print (" Motor # ");
      Serial.print (motorToMove); // should be 0 to 15 now
    else {
      goodCommand = 0;
      goodMotor = 17;
      //Serial.println ("bad command or motor");
    if (command == 'p' || command == 'P') {
      Serial.print (" Move to ");
      //upDown = 4;
      //motorCommand[motorToMove] = 4;
      moveCommand = 0xB; // need 5 characters still for 230,000
      // get 6 characters
      while (Serial.available() < 5) {
        // wait for more characters
      // got 6, continue
      for (x = 0; x < 6; x = x + 1) {
        charStep[x] = Serial.read() - 48; // read order is FEDCBA
        Serial.print (charStep[x], DEC);
      goToPosition =(charStep[0] * 100000) + (charStep[1] * 10000) +(charStep[2] * 1000) +(charStep[3] * 100) +(charStep[4] * 10) + charStep[5];
      Serial.print (" position: ");
      Serial.println (goToPosition, DEC);
(Off-topic: It would also be great if ‘p’ printed back as the command instead of 112, but the Serial.print() doesn’t seem to support doing that, that I could find.)
Results Examples:
Ready to Go.
 loop command 112
 Motor # 0 Move to 100000 position: 100000
 loop command 112
 Motor # 0 Move to 200000 position: 200000
 loop command 112
 Motor # 0 Move to 230000 position: 230000
 loop command 112
 Motor # 0 Move to 231000 position: 231000
 loop command 112
 Motor # 0 Move to 232000 position: 232000
 loop command 112
 Motor # 0 Move to 233000 position: 233000
 loop command 112
 Motor # 0 Move to 234000 position: 234000
 loop command 112
 Motor # 0 Move to 240000 position: 174464
 loop command 112
 Motor # 0 Move to 250000 position: 184464
 loop command 112
 Motor # 0 Move to 260000 position: 194464
 loop command 112
 Motor # 0 Move to 270000 position: 204464
 loop command 112
 Motor # 0 Move to 280000 position: 214464
 loop command 112
 Motor # 0 Move to 290000 position: 224464
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 Motor # 0 Move to 235000 position: 235000
 loop command 112
 Motor # 0 Move to 236000 position: 236000
 loop command 112
 Motor # 0 Move to 237000 position: 237000
 loop command 112
 Motor # 0 Move to 238000 position: 238000
 loop command 112
 Motor # 0 Move to 239000 position: 239000
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 loop command 112
 Motor # 0 Move to 239999 position: 239999
 loop command 112
[/code]
Printing 'p' rather than 112:
  Serial.println ((char)command);
Getting the calc right:
      goToPosition = (charStep[0] * 100000UL) + (charStep[1] * 10000UL) + (charStep[2] * 1000UL) + (charStep[3] * 100UL) + (charStep[4] * 10UL) + charStep[5];
Thanks wildbill, that seems to do it. I had tried putting (long) and long ( ) in there to no avail.
Been a while since I did any math like that, had forgotten but UL at the end of a number.
