[Solved] Convert Arduino Uno R3's 16U2 Microcontroller to ISP Programmer
Hi forum. I really need help.
I have got an Arduino Uno R3. Arduino Uno R3's has a programmed Atmel 16U2 microcontroller for converting Usb to TTL. This microcontroller can be programmed using "Flip" (With activating 16U2's DFU Mode)
Can i replace 16U2's Usb to TLL program with ArduinoISP program?
So, i want upload new bootloader or upload sketchs without bootloader (upload with programmer) without external programmer.
I can't buy a new programmer or a new arduino now.
Is that possible converting Uno R3's Usb To TTL 16U2 chip to ArduinoISP or an ISP (AVRISP, AVRISP mkii, etc.) (I mean i want use Arduino Uno R3 with self ISP)
If there are a hex file for them, i can upload it with "Flip" program.
Thanks :slight_smile:
Edit: I found this, but i can't get it to work. It starts to programming, but after a minute, it says usb timed out.
There is another thread in this forum titled Self-ISP on an Uno which covers this subject.
dmjlambert:
Yes, but it is for Uno R2 and it requires another Uno
Finally i fixed the problem. I used Atmel Studio for flashing.
Finally my Arduino Self-ISP itself.
Please remove the thread.
Programming:
Why?
Are you embarrassed?
If you want an even easier way of changing the firmware, look at HoodLoader2. It is a bootloader that turns your 16u2 into a Leonardo, a ISP, or a HID device. All it takes is a few wires. The installation sketch is uploaded to your Uno and it burns the 16u2!
HoodLoader:
Programming:
Why? Your solution may help others.
mart256:
Ok, i will explain the solution.
I never get it to work with avrdude.
But if i use AtmelStudio, it programs easily.
I worked very hard to get it work with avrdude, but i can't.
I installed drivers and hex file correct. (Driver is LibUSB)
Can i upload my sketches without Avrdude using Atmel Studio?
HoodLoader2 is not meant to be installed with Flip. It is a bootloader, not a firmware like HoodLoader. Read the HoodLoader2 wiki, especially the "Installation Sketch" page. That will give you a good understanding of how to use it. Also, the "Self-ISP on a Uno" will work on a R3, but yes you do need either a ISP, another Arduino, or a Usb-Serial convertor.
Isaac96:
I fixed it my problem, thanks for your help. I did it without another ISP device.
But, it is not working with AVRDUDE. It is only works with Atmel Studio. Can i upload my programs with Atmel Studio?
Will uploading hex file directly with Programmer section work?
Hold on. HoodLoader is not working with avrdude? Do you have the right MCU selected?
