Hello this is the first time that I tried my arduino with the Create Editor.
I started with the Blink example but it doesn't work. The board was correct detected as Arduino Duemilanove Port COM3. I use the same settings with the arduino ide. There the example worked.
The difference with Create Editor during upload only the RX led is blinking with the normal ide RX and TX was blinking. So it looks that the connection was working only in one direction.
The console output:
"/home/admin/builder/arduino-builder/packages/tools/arm-none-eabi-gcc/4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary "/tmp/731564307/Blink.ino.elf" "/tmp/731564307/Blink.ino.bin"
Sketch uses 22124 bytes (4%) of program storage space. Maximum is 524288 bytes.
Send auto-baud
Set binary mode
No device found on COM3
Could not program the board
As second try I uploaded the SerialCallResponse with the ide and look at the Create Editor Serial Monitor that was working fine!
I am working with the plugin 1.0.64 and windows 10. My board is the seeduino with an atmega 328.
I am not sure if the preselected board is relay correct -> without atmel selection. When I selected manually the Duemilanove, Com3 and Atmel328 it will not work, error and without any tx/rx blinking on my board.
@susay always make sure you select the Duemilanove and not the Due from the boards list. What do you mean with 'autoselect Arduino Due (Programming Port)'?
In your third try we see you correctly manually selected Arduino Duemilanove, Com3, Atmel 328. It looks like the AVRDude tool was not downloaded. Could you try to redo the exact same flow (maybe on Chrome) and see if this error still happens? Please always share the output.
We tried multiple times here but we cannot reproduce your issue.
When reload the website in firefox always the Due Programming Port is selected. This looks for me like a preselection. But maybe this is only a bug.
In Chrome I have to select always a board by my own.
What did you mean with "looks like the AVRDude tool was not downloaded". Have to install I more than the plugin?
I also tried to install the plugin again without benefit.
Thanks @susay,
we'll try to understand the issue from your logs.
About the 'preselection', the first time you link an unrecognized board to a specific board selected from the popup, the browser remebers what you selected the first time, so you need to press 'change' and select Duemilanove.
Hi @susay please help us in understanding the issue better by running the following commands in the form at the end of the debug console of the Arduino Create Agent.
log on
then send the message with the button and finally:
Hello, I had no more problems on my computers. To be sure I a searched for a new fresh system with same configuration.
I used a Windows 10 with Firefox and a Arduino Nano. I installed the plugin the first time. It worked perfect, no additional action required.
