[SOLVED] Creating instance of another class inside a class
Dear everyone
I’ve been building small Arduino projects as a hobby for a few years now. The devices are getting more complicated and I’ve ran into a situation, where my sketches get long with a bunch of variables and functions. Thus, it starts to make sense to create classes to make projects more manageable and also expandable (I might want to add a second or third led, maybe have an additional temperature sensor and so on).
As for background, there are some great tutorials (e.g. Arduino - LibraryTutorial) for creating Arduino libraries/classes and the basics seem to be working fine. But there’s one thing, I cannot wrap my mind around and I’ve also been unable to find a clear answer on the Internet/here.
Previously I would write like this (example for controlling a heatpump with Arduino).
//Ino without class
#include <MideaHeatpumpIR.h>
IRSenderPWM irSender(9);
HeatpumpIR *heatpumpIR = new MideaHeatpumpIR();
void setup(){
 heatpumpIR->send(irSender, POWER_ON, MODE_HEAT, FAN_2, 17, VDIR_UP, HDIR_AUTO);
 delay(5000);
 heatpumpIR->send(irSender, POWER_OFF, MODE_HEAT, FAN_2, 17, VDIR_UP, HDIR_AUTO);
 delay(5000);
void loop(){
when I transfer this bit of code into a class in my ino file, I declare the variables at the beginning (to make them available to my methods) and then create an instance in the constructor. For MideaHeatPumpIR I can create a new object. But what do with IRSender? I’ve tried creating a pointer (I think that’s what it’s called and using ->) among other things but I can’t seem to get it work.
Here’s the ino file
//Ino with class
class HeatPump{
  private:
  IRSenderPWM irSender(uint8_t);
  MideaHeatpumpIR *heatpumpIR;
  public:
  uint8_t temperature;
  uint8_t IRpin;
  HeatPump(uint8_t ir, uint8_t temp) {
    IRpin = ir;
    temperature = temp;
    IRSenderPWM irSender(ir);
  void start() {
    heatpumpIR->send(irSender, POWER_ON, MODE_HEAT, FAN_2, temperature, VDIR_UP, HDIR_AUTO);
  void stop() {
    heatpumpIR->send(irSender, POWER_OFF, MODE_HEAT, FAN_2, temperature, VDIR_UP, HDIR_AUTO);
  HeatPump garagePump(3, 20);
  garagePump.start();
  delay(5000);
  garagePump.stop();
  delay(5000);
And here’s the error:
Arduino: 1.8.7 (Windows 10), Board: “Arduino/Genuino Uno”
C:\Users\Ari\Documents\Arduino\sketch_feb04a\sketch_feb04a.ino: In member function ‘void HeatPump::start()’:
sketch_feb04a:21:91: error: invalid use of non-static member function
C:\Users\Ari\Documents\Arduino\sketch_feb04a\sketch_feb04a.ino: In member function ‘void HeatPump::stop()’:
sketch_feb04a:25:92: error: invalid use of non-static member function
exit status 1
“Show verbose output during compilation”
option enabled in File → Preferences.
Any help is greatly appreciated. Even if someone could point me to a resource that would explain the use of classes inside classes (I think that’s the case here) in rather simple terms for a hobbyist would be great. I guess, once I understand why the above isn’t working, I’ll be able to implement my classes correctly in the future.
First, I don’t see any compelling reason to use dynamic allocation to create the instance of MideaHeatpumpIR. So, I’d just do it statically.
I don’t have those libraries installed, so I can’t try to compile this. But, try something like this:
class HeatPump {
  private:
    IRSenderPWM irSender;
    MideaHeatpumpIR heatpumpIR;
  public:
    HeatPump(uint8_t ir, uint8_t temp) : irSender(ir), temperature(temp) {
    void start() {
      heatpumpIR.send(irSender, POWER_ON, MODE_HEAT, FAN_2, temperature, VDIR_UP, HDIR_AUTO);
    void stop() {
      heatpumpIR.send(irSender, POWER_OFF, MODE_HEAT, FAN_2, temperature, VDIR_UP, HDIR_AUTO);
PS - Google “c++ initializer list”
Thanks heaps!
It does actually compile and a quick Google search for initializer lists gave good results. I’ll post two links below, in case someone is strugling with the same issue.
https://www.learncpp.com/cpp-tutorial/8-5a-constructor-member-initializer-lists/
