[SOLVED] - Based on the advice of a few different people I slowly took the code apart and tested each part individually before plugging sections back in. I also tested the code on new sensors individually after seeing it working, I made a new wiring harness and retested. Worked perfectly!
Hey, I'm trying to write a sketch that will pull data from a BME280 and ADXL345 and then write that data to an SD card. Using different sketches I've found online I got something that I think should work, but isn't and I'm not sure what the issue is. Another issue I'm having is my BME sensor not working. I've got both sensors connected on a FeatherWing Proto as follows
Feather ADXL345 BME
SCL ------> SCL-------> SCK
SDA------> SDA-------> SDI
3V-------> VIN-------> VIN
GND-----> GND------> GND
3V-------> CS
Any insight as to where I went wrong would be greatly appreciated!
Hardware specs:
1x Feather M0 Adalogger
1x ADXL345
1x BME280
1x FeatherWing Proto
#include <SdFat.h> // SD card library
#include <Wire.h> // I2C wire lbrary
#include <Adafruit_BME280.h> // Pressure Sensor library
#include <Adafruit_Sensor.h> // Adafruit Sensor library
#include <Adafruit_ADXL345_U.h> // ADXL345 library
#define SEALEVELPRESSURE_HPA (1013.25)
#define RANGE_2_G 0;
int chipSelect = 4;
float hgInches = 29.97;
SdFat SD;
Adafruit_BME280 bme;
Adafruit_ADXL345_Unified accel = Adafruit_ADXL345_Unified(12345);
//turn on serial monitor
while (!Serial){
}// end while - serial
// initialize I2C bus
Wire.begin();
bool status;
//initialize BME sensor
status = bme.begin();
if (!status) {
Serial.println("No BME");
while (1);
} // end if - BME
//initialize ADXL sensor, range and data rate
status = accel.begin();
accel.setRange( ADXL345_RANGE_2_G );
accel.setDataRate( ADXL345_DATARATE_50_HZ );
if (!status) {
Serial.println("No ADXL");
while (1);
} // end if - accel
// initialize the SD card
Serial.print("Looking for SD: ");
if (!SD.begin(chipSelect)) {
Serial.println("SD not found ");
return;
} // end if - SD
Serial.println(" SD found");
// print a header in HAB Flight Data.txt
File flightData = SD.open("HAB Flight Data.txt", FILE_WRITE);
if (flightData) {
flightData.print("HAB FLight Data");
flightData.println("Temperature, Pressure, Altitude, Humidity, X-Axis, Y-Axis, Z-Axis");
flightData.println("_________________________________________________________________");
flightData.close();
} //end if - flightdata
} // end main setup
//var to hold sensor data
float BMEt1 = (bme.readTemperature());
float BMEh1 = (bme.readHumidity());
float BMEp1 = (bme.readPressure() / 100.0F);
float BMEa1 = (bme.readAltitude(SEALEVELPRESSURE_HPA));
// register events for ADXL
sensors_event_t event;
accel.getEvent(&event);
// print out BME data to serial monitor
Serial.println("BME Data.");
Serial.print("Temperature = "); Serial.print(BMEt1); Serial.println(" *F");
Serial.print("Pressure = "); Serial.print(BMEp1); Serial.println(" hPa");
Serial.print("Approx. Altitude = "); Serial.print(BMEa1); Serial.println(" meters");
Serial.print("Humidity = "); Serial.print(BMEh1); Serial.println(" %");
// print out ADXL data to serial monitor
Serial.println("Accelerometer Data");
Serial.print("X: "); Serial.print(event.acceleration.x); Serial.print(" ");
Serial.print("Y: "); Serial.print(event.acceleration.y); Serial.print(" ");
Serial.print("Z: "); Serial.print(event.acceleration.z); Serial.print(" ");
delay(1000); //Pause between readings.
// Create a txt file adn record data
if (flightData) {
flightData.print(BMEt1); flightData.print(","); flightData.print(BMEp1); flightData.print(",");
flightData.print(BMEa1); flightData.print(","); flightData.print(BMEh1); flightData.print(",");
flightData.println("X: "); flightData.print(event.acceleration.x); flightData.print(",");
flightData.println("Y: "); flightData.print(event.acceleration.y); flightData.print(",");
flightData.println("Z: "); flightData.print(event.acceleration.z); flightData.print(",");
flightData.close();
} // end if - data recorder
else {
Serial.println("error opening HAB Flight Data.txt");
} // end else - SD error
} //end Main loop
