[SOLVED] /dev/ttyUSB0 is not created
Hello! I just bought my first arduino and installed the software on Gentoo Linux. I have the usbserial, ftdi_sio and cdc_acm modules loaded, but /dev/ttyUSB0 is not created. DMESG see the Arduino just fne and ttyACM0 is created instead. What am I doing wrong?
lsmod
??(lepagee@localhost)???????????????????????????????????????????????????????????????????(~)??
??: lsmod        ??(Tue 20:06)??
Module                  Size  Used by
cdc_acm                13892  2
ftdi_sio               30673  0
usbserial              24555  1 ftdi_sio
nvidia              12206819  56
dmesg
[29010.373074] hub 2-0:1.0: state 7 ports 10 chg 0000 evt 0200
[29010.373083] ohci_hcd 0000:00:0b.0: GetStatus roothub.portstatus [8] = 0x00030100 PESC CSC PPS
[29010.373091] hub 2-0:1.0: port 9, status 0100, change 0003, 12 Mb/s
[29010.373095] usb 2-9: USB disconnect, device number 9
[29010.373098] usb 2-9: unregistering device
[29010.373101] usb 2-9: unregistering interface 2-9:1.0
[29010.379574] usb 2-9: unregistering interface 2-9:1.1
[29010.379626] usb 2-9: usb_disable_device nuking all URBs
[29010.483034] hub 2-0:1.0: debounce: port 9: total 100ms stable 100ms status 0x100
[29011.356418] hub 1-0:1.0: state 7 ports 10 chg 0000 evt 0200
[29011.356427] ehci_hcd 0000:00:0b.1: GetStatus port:9 status 001803 0  ACK POWER sig=j CSC CONNECT
[29011.356433] hub 1-0:1.0: port 9, status 0501, change 0001, 480 Mb/s
[29011.460019] hub 1-0:1.0: debounce: port 9: total 100ms stable 100ms status 0x501
[29011.511036] ehci_hcd 0000:00:0b.1: port 9 full speed --> companion
[29011.511042] ehci_hcd 0000:00:0b.1: GetStatus port:9 status 003001 0  ACK POWER OWNER sig=se0 CONNECT
[29011.511081] hub 1-0:1.0: port 9 not reset yet, waiting 50ms
[29011.562055] ehci_hcd 0000:00:0b.1: GetStatus port:9 status 003802 0  ACK POWER OWNER sig=j CSC
[29011.562077] hub 1-0:1.0: state 7 ports 10 chg 0000 evt 0200
[29011.562088] hub 2-0:1.0: state 7 ports 10 chg 0000 evt 0200
[29011.562094] ohci_hcd 0000:00:0b.0: GetStatus roothub.portstatus [8] = 0x00010101 CSC PPS CCS
[29011.562098] hub 2-0:1.0: port 9, status 0101, change 0001, 12 Mb/s
[29011.666034] hub 2-0:1.0: debounce: port 9: total 100ms stable 100ms status 0x101
[29011.728028] ohci_hcd 0000:00:0b.0: GetStatus roothub.portstatus [8] = 0x00100103 PRSC PPS PES CCS
[29011.779016] usb 2-9: new full-speed USB device number 10 using ohci_hcd
[29011.842015] ohci_hcd 0000:00:0b.0: GetStatus roothub.portstatus [8] = 0x00100103 PRSC PPS PES CCS
[29011.908013] usb 2-9: ep0 maxpacket = 8
[29011.915490] usb 2-9: skipped 3 descriptors after interface
[29011.918491] usb 2-9: default language 0x0409
[29011.927489] usb 2-9: udev 10, busnum 2, minor = 137
[29011.927492] usb 2-9: New USB device found, idVendor=2341, idProduct=0010
[29011.927495] usb 2-9: New USB device strings: Mfr=1, Product=2, SerialNumber=220
[29011.927498] usb 2-9: Product: Arduino Mega 2560
[29011.927500] usb 2-9: Manufacturer: Arduino (www.arduino.cc)
[29011.927502] usb 2-9: SerialNumber: 93140364233351410292
[29011.927563] usb 2-9: usb_probe_device
[29011.927568] usb 2-9: configuration #1 chosen from 1 choice
[29011.930497] usb 2-9: adding 2-9:1.0 (config #1, interface 0)
[29011.930581] cdc_acm 2-9:1.0: usb_probe_interface
[29011.930585] cdc_acm 2-9:1.0: usb_probe_interface - got id
[29011.930625] cdc_acm 2-9:1.0: ttyACM0: USB ACM device
[29011.936545] usb 2-9: adding 2-9:1.1 (config #1, interface 1)
[29011.936591] drivers/usb/core/inode.c: creating file '010'
[29011.936612] hub 2-0:1.0: state 7 ports 10 chg 0000 evt 0200
??: ls /dev/tty*                                                              ??(Tue 20:24)??
/dev/tty    /dev/tty17  /dev/tty26  /dev/tty35  /dev/tty44  /dev/tty53  /dev/tty62
/dev/tty0   /dev/tty18  /dev/tty27  /dev/tty36  /dev/tty45  /dev/tty54  /dev/tty63
/dev/tty1   /dev/tty19  /dev/tty28  /dev/tty37  /dev/tty46  /dev/tty55  /dev/tty7
/dev/tty10  /dev/tty2   /dev/tty29  /dev/tty38  /dev/tty47  /dev/tty56  /dev/tty8
/dev/tty11  /dev/tty20  /dev/tty3   /dev/tty39  /dev/tty48  /dev/tty57  /dev/tty9
/dev/tty12  /dev/tty21  /dev/tty30  /dev/tty4   /dev/tty49  /dev/tty58  /dev/ttyACM0
/dev/tty13  /dev/tty22  /dev/tty31  /dev/tty40  /dev/tty5   /dev/tty59  /dev/ttyS0
/dev/tty14  /dev/tty23  /dev/tty32  /dev/tty41  /dev/tty50  /dev/tty6   /dev/ttyS1
/dev/tty15  /dev/tty24  /dev/tty33  /dev/tty42  /dev/tty51  /dev/tty60  /dev/ttyS2
/dev/tty16  /dev/tty25  /dev/tty34  /dev/tty43  /dev/tty52  /dev/tty61  /dev/ttyS3
kernel config http://pastebin.com/8updEjtw
I bought an Arduino mega from sparkfun. Using the java gui on ACM0 show some noise at 110kbps. It is probably quite simple, but I have no idea.
Link to the exact board you bought.
"[29011.927498] usb 2-9: Product: Arduino Mega 2560"
From DMESG
Uh.
A *web*link to the board you bought.
http://www.abra-electronics.com/products/A000067-Arduino-Mega-2560-Rev.3.html
But I will change my question is ACM0 a valid device or do I need USB0?
I’m confused.
Elv13:
You said you bought it from Sparkfun, I asked for a link to the one you bought and you provided:
Elv13:
So, where did you buy it?
The reason for the question is if you didn’t buy a genuine Arduino, it is necessary to understand what you actually have before proper help can be given. Generally, people aren’t tripped up on the “where did you buy it” question. A picture of one that “looks like mine” isn’t good enough. You might not notice the differences, but experienced users do.
Elv13:
Yes ACM0 is valid. Your test was not:
Elv13:
So? Was there any serial code running on Arduino? If not, what difference does it make what you saw. Why 110kps? If there WAS serial code running on the Arduino, did you set the baud rate to 110kps in the sketch?
I am new with AVR, I have a lot of newb problems (switching from PIC and T.I. LaunchPad. About SparkFun, it is our local sparkfun reseller, it just have another name, but they sell SparkFun boards (and a few other suppliers from the world wide web). My board is genuine, I got the stickers, and the paperwork say it is Arduino and manifactured and validated under license, warrant that it is 100% conform to specifications.
Back to newb stuff. If ACM0 is valid, why do I get
arvdude: usbdev_open(): did not find any USB device "usb"
Error message? Is the last stable version too old? I use Arduino 1.0 / avrdude 5.11.1.
EDIT: I had the wrong settings, work now
