i have purchased DFrobot SEN0501 ,i downloaded the needed libraries but the code is not compiling using arduino 1.8.13 on windows 10
Here is the code that i have used
#include "DFRobot_EnvironmentalSensor.h"
#if defined(ARDUINO_AVR_UNO)||defined(ESP8266)
#include <SoftwareSerial.h>
#endif
#define MODESWITCH /*UART:*/1 /*I2C: 0*/
#define SEN0501_DEFAULT_DEVICE_ADDRESS 0x22
#if MODESWITCH
SoftwareSerial mySerial(/*rx =*/4, /*tx =*/5);
DFRobot_EnvironmentalSensor environment(/*addr =*/SEN0501_DEFAULT_DEVICE_ADDRESS, /*s =*/&mySerial);
#else
DFRobot_EnvironmentalSensor environment(/*addr =*/SEN0501_DEFAULT_DEVICE_ADDRESS, /*s =*/&Serial1);
#endif
#else
DFRobot_EnvironmentalSensor environment(/*addr = */SEN0501_DEFAULT_DEVICE_ADDRESS, /*pWire = */&Wire);
#endif
#if MODESWITCH
//Init MCU communication serial port
mySerial.begin(9600);
#elif defined(ESP32)
Serial1.begin(9600, SERIAL_8N1, /*rx =*/D3, /*tx =*/D2);
#else
Serial1.begin(9600);
#endif
#endif
while(environment.begin() != 0){
Serial.println(" Sensor initialize failed!!");
Serial.println(" Sensor initialize success!!");
//Print the data obtained from sensor
Serial.println("-------------------------------");
Serial.print("Temp: ");
Serial.print(environment.getTemperature(TEMP_C));
Serial.println(" ℃");
Serial.print(environment.getTemperature(TEMP_F));
Serial.println(" ℉");
Serial.print("Humidity: ");
Serial.print(environment.getHumidity());
Serial.println(" %");
Serial.print("Ultraviolet intensity: ");
Serial.print(environment.getUltravioletIntensity());
Serial.println(" mw/cm2");
Serial.print("LuminousIntensity: ");
Serial.print(environment.getLuminousIntensity());
Serial.println(" lx");
Serial.print("Atmospheric pressure: ");
Serial.print(environment.getAtmospherePressure(HPA));
Serial.println(" hpa");
Serial.print("Altitude: ");
Serial.print(environment.getElevation());
Serial.println(" m");
i got these errors
Arduino: 1.6.5 (Windows 8.1), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Build options changed, rebuilding all
C:\Users\OneDrive\Pictures\arduino-1.6.5-r5\libraries\DFRobot_EnvironmentalSensor\src\Wire.cpp: In member function 'uint8_t TwoWire::requestFrom(uint8_t, uint8_t, uint8_t)':
C:\Users\OneDrive\Pictures\arduino-1.6.5-r5\libraries\DFRobot_EnvironmentalSensor\src\Wire.cpp:85:68: error: too many arguments to function 'uint8_t twi_readFrom(uint8_t, uint8_t*, uint8_t)'
- uint8_t read = twi_readFrom(address, rxBuffer, quantity, sendStop);
In file included from C:\Users\amr42\OneDrive\Pictures\arduino-1.6.5-r5\libraries\DFRobot_EnvironmentalSensor\src\Wire.cpp:26:0:
C:\Users\OneDrive\Pictures\arduino-1.6.5-r5\libraries\DFRobot_EnvironmentalSensor\src\twi.h:43:11: note: declared here
uint8_t twi_readFrom(uint8_t, uint8_t*, uint8_t);
C:\Users\OneDrive\Pictures\arduino-1.6.5-r5\libraries\DFRobot_EnvironmentalSensor\src\Wire.cpp: In member function 'uint8_t TwoWire::endTransmission(uint8_t)':
C:\Users\OneDrive\Pictures\arduino-1.6.5-r5\libraries\DFRobot_EnvironmentalSensor\src\Wire.cpp:140:76: error: too many arguments to function 'uint8_t twi_writeTo(uint8_t, uint8_t*, uint8_t, uint8_t)'
int8_t ret = twi_writeTo(txAddress, txBuffer, txBufferLength, 1, sendStop);
In file included from C:\Users\OneDrive\Pictures\arduino-1.6.5-r5\libraries\DFRobot_EnvironmentalSensor\src\Wire.cpp:26:0:
C:\Users\OneDrive\Pictures\arduino-1.6.5-r5\libraries\DFRobot_EnvironmentalSensor\src\twi.h:44:11: note: declared here
uint8_t twi_writeTo(uint8_t, uint8_t*, uint8_t, uint8_t);
Error compiling.
any help how to solve this ?
libraries.zip (48.4 KB)
