Solved - DFRobot W5500 sketch doesn't startwith ext.supply?
I do not what is going on. I use DFRobot Ethernet W5500 board and when I create wery simple sketch like this:
  pinMode(13, OUTPUT);
   while(!Serial);
  Serial.println(F("TEST"));
  digitalWrite(13, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                   // wait for a second
  digitalWrite(13, LOW);    // turn the LED off by making the voltage LOW
it doesn't start when I'm powering the board with an external power supply? To be honest program start when I start "Serial monitor".
Problem doesn't appear when I comment everything related with serial port.
Do you know how to mitigate this problem?
Regards
Michał
I've solved a problem, line
while(!Serial);
should be removed. In documentation we read "if(Serial) This will only return false if querying the Leonardo's USB CDC serial connection before it is ready."
So is your problem solved, or not? If so, modify the subject line of your first post here to add "(Solved)". (Do not remove any other part of it.)
