i've tried adding the display-on-command and working with this tutorial (german):
http://www.mikrocontroller.net/articles/AVR_LCD_KS0073/DIP204_mit_Hardware-SPI
but i still got nothing displayed...
here my full code:
//http://arduino.cc/en/Reference/SPI
// include the SPI library:
#include <SPI.h>
#define COMMAND 0b00011111 // Command start byte
#define WRITE_DATA 0b01011111 // Write Data start byte
11 (MOSI) -> 5 (SID)
12 (MISO) -> 7 (SOD)
13 (SCK) -> 6 (SCLK)
10 (SS) -> 4 (CS)
PULLUP ca. 22k (5V - 22k - CS)
GND -> 1 (VSS)
GND -> 18 (LED-)
5V -> 2 (VDD)
5V-10k-
\_ 3 (VEE)
5V-100-1k-
\_ 17 (LED+)
//int chartable[255];
// set pin 10 as the slave select for the digital pot:
//const int slaveSelectPin = 10; //UNO
const int slaveSelectPin = 53; //MEGA
// set the slaveSelectPin as an output:
pinMode (slaveSelectPin, OUTPUT);
delay(5000);
//data for lcd dip204-4
//http://www.mikrocontroller.net/articles/AVR_LCD_KS0073/DIP204_mit_Hardware-SPI
SPI.setBitOrder(LSBFIRST);
SPI.setDataMode(SPI_MODE3);
SPI.setClockDivider(SPI_CLOCK_DIV64);
// initialize SPI:
SPI.begin();
//lcd-init
lcd_write_data(true,0x34); // 34 0011 0100 (8Bit Bus, RE=1)
lcd_write_data(true,0x09); // 09 0000 1001 (4 Zeilen Mode)
lcd_write_data(true,0x30); // 30 0011 0000 (8Bit Bus, N=0, RE=0, DH=0, REV=0)
lcd_write_data(true,0x0F); // 0F 0000 1111 (Display ein, Cursor ein, Cursor Blinken)
//lcd_write_data(true,0x0C); // 0C 0000 1100 (Display ein, Cursor aus, Cursor Blinken aus)
lcd_write_data(true,0x01); // 01 0000 0001 (Display löschen, cursor auf 0,0)
lcd_write_data(true,0x06); // 06 0000 0110 (Display löschen, cursor auf 0,0)
* Zeile 1: 0x00 (bis 0x13)
* Zeile 2: 0x20 (bis 0x33)
* Zeile 3: 0x40 (bis 0x53)
* Zeile 4: 0x60 (bis 0x73)
lcd_write(0x00,byte('1'));//1.Zeile,1.Spalte
lcd_write(0x01,byte('A'));//1.Zeile,2.Spalte
lcd_write(0x20,byte('2'));//2.Zeile,1.Spalte
lcd_write(0x21,byte('B'));//2.Zeile,2.Spalte
lcd_write(0x40,byte('3'));//3.Zeile,1.Spalte
lcd_write(0x41,byte('C'));//3.Zeile,2.Spalte
lcd_write(0x60,byte('4'));//4.Zeile,1.Spalte
lcd_write(0x61,byte('D'));//4.Zeile,2.Spalte
SetCursor(0,2);//1.Zeile, 3.Spalte
lcd_write_data(false,'#');
SetCursor(1,5);//2.Zeile, 6.Spalte
lcd_write_data(false,'+');
SetCursor(2,7);//3.Zeile, 8.Spalte
lcd_write_data(false,'%');
SetCursor(3,9);//4.Zeile, 10.Spalte
lcd_write_data(false,'!');
static const unsigned char BitReverseTable256[] =
0x00, 0x80, 0x40, 0xC0, 0x20, 0xA0, 0x60, 0xE0, 0x10, 0x90, 0x50, 0xD0, 0x30, 0xB0, 0x70, 0xF0,
0x08, 0x88, 0x48, 0xC8, 0x28, 0xA8, 0x68, 0xE8, 0x18, 0x98, 0x58, 0xD8, 0x38, 0xB8, 0x78, 0xF8,
0x04, 0x84, 0x44, 0xC4, 0x24, 0xA4, 0x64, 0xE4, 0x14, 0x94, 0x54, 0xD4, 0x34, 0xB4, 0x74, 0xF4,
0x0C, 0x8C, 0x4C, 0xCC, 0x2C, 0xAC, 0x6C, 0xEC, 0x1C, 0x9C, 0x5C, 0xDC, 0x3C, 0xBC, 0x7C, 0xFC,
0x02, 0x82, 0x42, 0xC2, 0x22, 0xA2, 0x62, 0xE2, 0x12, 0x92, 0x52, 0xD2, 0x32, 0xB2, 0x72, 0xF2,
0x0A, 0x8A, 0x4A, 0xCA, 0x2A, 0xAA, 0x6A, 0xEA, 0x1A, 0x9A, 0x5A, 0xDA, 0x3A, 0xBA, 0x7A, 0xFA,
0x06, 0x86, 0x46, 0xC6, 0x26, 0xA6, 0x66, 0xE6, 0x16, 0x96, 0x56, 0xD6, 0x36, 0xB6, 0x76, 0xF6,
0x0E, 0x8E, 0x4E, 0xCE, 0x2E, 0xAE, 0x6E, 0xEE, 0x1E, 0x9E, 0x5E, 0xDE, 0x3E, 0xBE, 0x7E, 0xFE,
0x01, 0x81, 0x41, 0xC1, 0x21, 0xA1, 0x61, 0xE1, 0x11, 0x91, 0x51, 0xD1, 0x31, 0xB1, 0x71, 0xF1,
0x09, 0x89, 0x49, 0xC9, 0x29, 0xA9, 0x69, 0xE9, 0x19, 0x99, 0x59, 0xD9, 0x39, 0xB9, 0x79, 0xF9,
0x05, 0x85, 0x45, 0xC5, 0x25, 0xA5, 0x65, 0xE5, 0x15, 0x95, 0x55, 0xD5, 0x35, 0xB5, 0x75, 0xF5,
0x0D, 0x8D, 0x4D, 0xCD, 0x2D, 0xAD, 0x6D, 0xED, 0x1D, 0x9D, 0x5D, 0xDD, 0x3D, 0xBD, 0x7D, 0xFD,
0x03, 0x83, 0x43, 0xC3, 0x23, 0xA3, 0x63, 0xE3, 0x13, 0x93, 0x53, 0xD3, 0x33, 0xB3, 0x73, 0xF3,
0x0B, 0x8B, 0x4B, 0xCB, 0x2B, 0xAB, 0x6B, 0xEB, 0x1B, 0x9B, 0x5B, 0xDB, 0x3B, 0xBB, 0x7B, 0xFB,
0x07, 0x87, 0x47, 0xC7, 0x27, 0xA7, 0x67, 0xE7, 0x17, 0x97, 0x57, 0xD7, 0x37, 0xB7, 0x77, 0xF7,
0x0F, 0x8F, 0x4F, 0xCF, 0x2F, 0xAF, 0x6F, 0xEF, 0x1F, 0x9F, 0x5F, 0xDF, 0x3F, 0xBF, 0x7F, 0xFF
int SetCursor(byte row, byte col)
int row_offsets[] = { 0x00, 0x20, 0x40, 0x60 };
#define LCD_SETDDRAMADDR 0x80
// command(LCD_SETDDRAMADDR | (col + row_offsets[row]));
lcd_write_data(true,LCD_SETDDRAMADDR | (col + row_offsets[row]));
byte reversebyte(byte value)
byte res=0;
res=res|(value & 1)<<7;
res=res|(value & 2)<<5;
res=res|(value & 4)<<3;
res=res|(value & 8)<<1;
res=res|(value & 16)>>1;
res=res|(value & 32)>>3;
res=res|(value & 64)>>5;
res=res|(value & 128)>>7;
return res;
//return value;
int lcd_write_data(bool command,byte value)
// take the SS pin low to select the chip:
digitalWrite(slaveSelectPin,LOW);
int lowerdata=value & 0x0f;
int upperdata=(value & 0xf0) >> 4;
if (command)
SPI.transfer(reversebyte(COMMAND));
SPI.transfer(reversebyte(WRITE_DATA));
SPI.transfer(reversebyte(lowerdata));
SPI.transfer(reversebyte(upperdata));
// take the SS pin high to de-select the chip:
digitalWrite(slaveSelectPin,HIGH);
any idea?
regards Frank
