[SOLVED] DS1307 RTC date and time to convert to string for TFT LCD
Good day!
Please hear me out :-[
I know there's a lot of post regarding converting date and time to string but I assure you Serial.print(now.year(), DEC) is not the answer.
I'm using Arduino MEGA 2560 with a TFT LCD + Touch + SD Card Slot along with its Shield and a TinyRTC Module with DS1307 chip.
I can read and display the date and time. I store the it to SD so I can convert it to string then I print them to the LCD. The problem is I have to constantly save and read values to SD and I think it will affect the time process of my project.
Why don't I print it directly? Text printing in TFT LCD is different. I have to use myGLCD.print(String, x coordinate, y coordinate, deg);
If I want to get the values from the module I have to do this
void saveTime()
   DateTime now;
  // fetch the time
  now = RTC.now();
  // Delete the old One
  SD.remove("time.txt");
  // Create new one
  logfile = SD.open("time.txt", FILE_WRITE);
  // writing in the file works just like regular print()/println() function
  logfile.print("Date/Time=");
  logfile.print(now.year(), DEC);
  logfile.print("/");
  logfile.print(now.month(), DEC);
  logfile.print("/");
  logfile.print(now.day(), DEC);
  logfile.print(", ");
  logfile.print(now.hour(), DEC);
  logfile.print(":");
  logfile.print(now.minute(), DEC);
  logfile.print(":");
  logfile.println(now.second(), DEC);
  // close the file:
  logfile.close();
I don't know how to I can store the decimal configuration of now.[date and time] I hope you can help me
Look into sprintf(), it will be very helpful.
Thank you for the reply Sir HazardsMind!
I used this code
void fetchTime()
  DateTime now;
  // fetch the time
  now = RTC.now();
  char buffer [25] = "";
  sprintf(buffer, "%04d/%02d/%02d, %02d:%02d:%02d", now.year(), now.month(), now.day(), now.hour(), now.minute(), now.second());
  dateTime = buffer;
  //Serial.print(buffer);
It works! Thank you very much :D
Hello arduinoTime, do you still have the code. I have some issues compilated the code. I try to have the Time and date.
