[SOLVED]Ds3231 set alarms A1 & A2 once per day in different hours.. every day.
Hi i'm trying to set the alarms A1 and A2 to trigger an event twice per day... lets say at 10 and 20 hour in 24 hour format.
According to this found in https://github.com/simonkuang/DS3231
Serial.println("A1 to fire every minute at 30 Seconds");
           //WARNING!! It is possible to set stupid values eg 43rd day of a month, or 27th Hour or 70th Minute
           //The values shown for Alarm 1 & 2 are the 'acceptable' ranges or values
           // There are two other sketches to help with Interupts
           // 1) Clock_Read_Alarm.ino Displays settings for both alarms
           // 2) Clock_Test_Int.ino Simple example of using an external interupt
  ADay=23;         //If ADoW is False ADay Value is 1 to 31 or if ADoW is True ADay Value is 1 to 7
  AHour=12;        // If A12h=False Hour is 00 to 23 or if A12h=True Hour is 01 to 12
  AMinute=34;      // Minutes = 00 to 59
  ASecond=30;      // Seconds= 00 to 59
  ABits=14;        //Match Type Values. 0=Day/Date, 8=Hrs/Min/Sec, 12=Min/Sec, 14=Sec, 15=Every Sec
  ADoW=false;      //False= Match on Date, True= Match on DoW
  A12h=false;      //False= Use 24Hour Clock format, True= Use 12Hour Clock format
  Apm=false;       // If False time is 1AM to 12AM, if True time is 1PM to 12PM
  Clock.setA1Time(ADay, AHour, AMinute, ASecond, ABits, ADoW, A12h, Apm);
  Clock.turnOffAlarm(1);
  // Now to turn or attention to Alarm 2.
  /* The main difference with Alarm 2 is in the Alarm Mask Bits.
   it is only possible to fire the alarm down to a minute, i.e. you cannot specify
   it down to the second. All matches occur at 00 seconds
  Serial.println("A2 to fire Every Minute at 00 Seconds");
  ADay=2;      //If ADoW is False ADay Value is 1 to 31 or if ADoW is True ADay Value is 1 to 7
  AHour=7;         //If A12h=False Hour is 00 to 23 or if A12h=True Hour is 01 to 12
  AMinute=25;      // Minutes 00 to 59
  ABits=112;       //Match Type Values. 0=Day/Date, 64=Hrs/Min, 96=Min, 112=Every Minute
  Clock.setA2Time(ADay, AHour, AMinute, ABits, ADoW, A12h, Apm);
  Clock.turnOffAlarm(2);
if i understand correctly i must set the following values
FOR A1
Clock.setA1Time(ADay, AHour, AMinute, ASecond, ABits, ADoW, A12h, Apm); .....................................00..........10...........00...........00...........8........false...false...false
FOR A2
Clock.setA2Time(ADay, AHour, AMinute, ABits, ADoW, A12h, Apm); ......................................00.........20...........00........64.....false....false..false
with the above setup the A1 will trigger an alarm at 10:00 and A2 at 20:00 ...right ?
I m not sure on how do i have to set the first value of each alarm ADay sould be set as 00 or something else to trigger the alarm every day of the month in the defined hour ?
Thank you in advance.
The above example working !!!
Just in case someone else is interested !
ntgr: The above example working !!!
Worked like a champ for me! Thanks for posting the original code and coming back to validate it working.
Thanks!!!!!
