Reciever code:
ESP32_CameraServer_AP_20220120.ino (6.2 KB)
Don't you just LOVE comments in JAPANESE???
Reciever code:
My reason for asking is; I have built a few of these kits and helped with owners on this forum (none with python), and even though they all had little problems, they worked "out of the box".
Elegoo has trouble printing good material, but the stuff eventually works (if you edit what they wrote).
What I am now saying sounds like a waste of time: I would un-do whatever was done with the Elegoo code and start fresh.
Ok.
um, not so much..
if (false == data_begin && c == '}')
that's the trigger, not looking for newline..
it should also be serial printing every char received to the serial monitor??
what you getting??
~q
Absolutely nothing.
can't be getting anything..
if (client.available()) //如果有可读数据
char c = client.read(); //读取一个字节
Serial.print(c);
the char prints to serial after received from client..
~q
That's the problem. I don't stinking care about a response, I just want the robot to move when I teell it to. Data goes in, nada comes out.
do you see this print??
Serial.println("[Client connected]");
~q
Nope
strange as one of your pics shows you receiving this, maybe i'm mistaken..
client.print("{Heartbeat}");
~q
True, it did. That's confusing
Chinese.
Here is that file with translations...
* @Descripttion:
* @version:
* @Author: Elegoo
* @Date: 2020-06-04 11:42:27
* @LastEditors: Changhua
* @LastEditTime: 2020-09-07 09:40:03
//#include <EEPROM.h>
#include "CameraWebServer_AP.h"
#include <WiFi.h>
#include "esp_camera.h"
WiFiServer server(100);
#define RXD2 33
#define TXD2 4
CameraWebServer_AP CameraWebServerAP;
bool WA_en = false;
void SocketServer_Test(void)
static bool ED_client = true;
WiFiClient client = server.available(); //尝试建立客户对象 // Try to establish a customer object
if (client) //如果当前客户可用 // If available to a current customer
WA_en = true;
ED_client = true;
String readBuff;
String sendBuff;
uint8_t Heartbeat_count = 0;
bool Heartbeat_status = false;
bool data_begin = true;
while (client.connected()) //如果客户端处于连接状态 // If the client is connected
if (client.available()) //如果有可读数据 // If there is readable data
char c = client.read(); //读取一个字节 // Read a byte
Serial.print(c); //从串口打印 // Print from serial port
if (true == data_begin && c == '{') //接收到开始字符 // The start character is received
data_begin = false;
if (false == data_begin && c != ' ') //去掉空格 // Remove the whitespace
readBuff += c;
if (false == data_begin && c == '}') //接收到结束字符 // Receives the end character
data_begin = true;
if (true == readBuff.equals("{Heartbeat}"))
Heartbeat_status = true;
Serial2.print(readBuff);
//Serial2.print(readBuff);
readBuff = "";
if (Serial2.available())
char c = Serial2.read();
sendBuff += c;
if (c == '}') //接收到结束字符 // Receives the end character
client.print(sendBuff);
Serial.print(sendBuff); //从串口打印 // Print from serial port
sendBuff = "";
static unsigned long Heartbeat_time = 0;
if (millis() - Heartbeat_time > 1000) //心跳频率 // Heart rate
// if (true == Heartbeat_status)
// Heartbeat_status = false;
// Heartbeat_count = 0;
// else if (false == Heartbeat_status)
// Heartbeat_count += 1;
// if (Heartbeat_count > 3)
// break;
Heartbeat_time = millis();
static unsigned long Test_time = 0;
if (millis() - Test_time > 1000) //定时检测连接设备 // Detect connected devices at regular intervals
Test_time = millis();
//Serial2.println(WiFi.softAPgetStationNum());
if (0 == (WiFi.softAPgetStationNum())) //如果连接的设备个数为“0” 则向车模发送停止命令 // If the number of connected devices is "0", a stop command is sent to the model car
Serial2.print("{\"N\":100}");
client.stop(); //结束当前连接 // To end the current connection::
Serial.println("[Client disconnected]");
if (ED_client == true)
ED_client = false;
/*作用于测试架 // Acting on the test stand */
void FactoryTest(void)
static String readBuff;
String sendBuff;
readBuff += c;
if (true == readBuff.equals("{BT_detection}"))
Serial2.print("{BT_OK}");
Serial.println("Factory...");
else if (true == readBuff.equals("{WA_detection}"))
Serial2.print("{");
Serial2.print(CameraWebServerAP.wifi_name);
Serial2.print("}");
readBuff = "";
if ((WiFi.softAPgetStationNum())) //连接的设备个数不为“0” led指示灯长亮 // The number of connected devices is not "0" and the LED indicator is always on
if (true == WA_en)
digitalWrite(13, LOW);
Serial2.print("{WA_OK}");
WA_en = false;
//获取时间戳 // Get the timestamp
static unsigned long Test_time;
static bool en = true;
if (millis() - Test_time > 100)
if (false == WA_en)
Serial2.print("{WA_NO}");
WA_en = true;
if (en == true)
en = false;
digitalWrite(13, HIGH);
en = true;
Serial2.begin(9600, SERIAL_8N1, RXD2, TXD2);
//http://192.168.4.1/control?var=framesize&val=3
//http://192.168.4.1/Test?var=
CameraWebServerAP.CameraWebServer_AP_Init();
server.begin();
delay(100);
// while (Serial.read() >= 0)
// /*清空串口缓存 // Clear the serial cache...*/
// while (Serial2.read() >= 0)
pinMode(13, OUTPUT);
Serial.println("Elegoo-2020...");
Serial2.print("{Factory}");
SocketServer_Test();
FactoryTest();
C:\Program Files (x86)\Arduino\hardware\espressif\arduino-esp32/tools/esptool/esptool.exe --chip esp32 --port COM6 --baud 460800 --before default_reset --after hard_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect
0xe000 C:\Program Files (x86)\Arduino\hardware\espressif\arduino-esp32/tools/partitions/boot_app0.bin
0x1000 C:\Program Files (x86)\Arduino\hardware\espressif\arduino-esp32/tools/sdk/bin/bootloader_qio_80m.bin
0x10000 C:\Users\Faynman\Documents\Arduino\Hex/CameraWebServer_AP_20200608xxx.ino.bin
0x8000 C:\Users\Faynman\Documents\Arduino\Hex/CameraWebServer_AP_20200608xxx.ino.partitions.bin
flash:path
C:\Program Files (x86)\Arduino\hardware\espressif\arduino-esp32\tools\partitions\boot_app0.bin
C:\Program Files (x86)\Arduino\hardware\espressif\arduino-esp32\tools\sdk\bin\bootloader_dio_40m.bin
C:\Users\Faynman\Documents\Arduino\Hex\CameraWebServer_AP_20200608xxx.ino.partitions.bin
//esptool.py-- port / dev / ttyUSB0-- baub 261216 write_flash-- flash_size = detect 0 GetChipID.ino.esp32.bin
Hey, thanks!
In you python, connect, don't send but just wait and read..
Do you get a {Heartbeat} every second??
~q
No, they're commented out in 80 - 94 in esp32.....ino
No, still in the code..
looks like it sends this once per second while the client is connected..
thinking that's where it came from inside the python pic you posted??
~q
Yes. That's where its from, but why not every second? It sent the first one, never sent a second.
I noticed that it only sends a heartbeat after you unconnect and reconnect.
and you never get a connected printed??
starting to sound very strange..
make sure your windows firewall is turned off..
try a different port, don't particularity like the low port number..
ports 0-1023 are reserved..
WiFiServer server(10000);
might be better..
strange.. ~q
Tried both. Neither worked.
I put a command in the serial monitor and the robot executes it fine, but anything with wifi, it just doesn't work.
