[Solved] Error after compiling
I don’t know if I’m at the appropiate section, but I think this is the closest it get. ::slight_smile:
I was building my RFID-lock and everything ran smoothly, but…
After I got my script up and running I started cleaning my script (remove unwanted spaces, clean empty lines etc.). I noticed that there has occured an error during compiling. The annoying this is that I can’t figure out what I’m missing. I’m afraid I erased an essential element but I just can’t find it … :-[ I’ve been trying all afternoon now and I know the answer is simple. I just can’t figure it out :’(
The error I keep getting tells me the following:
error: expected constructor, destructor, or type conversion before '=' token
I tried looking in google but it didn’t helped me one bit >:(
So basicly, the code was fine until I cleaned it up a bit :-[
Here it is:
#include <Servo.h>
#define TAG_LEN 12
Servo myservo;  // create servo object to control a servo
char tag[12] = {'*', '*', '*', '*', '*', '*', '*', '*', '*', '*'};      // First tag
char tag_2[12] = {'*', '*', '*', '*', '*', '*', '*', '*', '*', '*'};     // Second tag
char code[12];
int bytesread = 0;
int ledPin = 11; // Connect LED to pin 13
int ledPin2 = 13;
int rfidPin = 2; // RFID enable pin connected to digital pin 2
int val = 0;
// -------AUDIO------
int speakerPin = 11;
int length = 15; // the number of notes
char notes[] = "cdefgabC ";            // Melody for correct tag
char notes_2[] = "ccc ";                 // Melody for incorrect tag
int beats[] = {1, 1, 1, 1, 1, 1, 2, 1, 1, 1, 1, 1, 1, 2, 4 };         // beat length
int tempo = 50;                                                        // speed of the melody
void playTone(int tone, int duration) {
  for (long i = 0; i < duration * 1000L; i += tone * 2) {
    digitalWrite(speakerPin, HIGH);
    delayMicroseconds(tone);
    digitalWrite(speakerPin, LOW);
void playNote(char note, int duration) {
  char names[] = {'c', 'd', 'e', 'f', 'g', 'a', 'b', 'C'};
  int tones[] = {1915, 1700, 1519, 1432, 1275, 1136, 1014, 956};
  // play the tone corresponding to the note name
  for (int i = 0; i < 8; i++) {
    if (names[i] == note) {
      playTone(tones[i], duration);
  pinMode(speakerPin, OUTPUT);
  Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
  pinMode(rfidPin,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
  pinMode(ledPin,OUTPUT); // Set ledPin to output
  digitalWrite(rfidPin, LOW); // Activate the RFID reader
  digitalWrite(ledPin, HIGH);
  delay(100);
  digitalWrite(ledPin, LOW);
  delay(100);
  delay(100);
  myservo.attach(9);  // attaches the servo on pin 2 to the servo object
  myservo.write(0);   // set servo position
  // ---------------------------- READING TAG -----------------------------\\
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread >= 10) {              // if 10 digit read is complete
        // ---------------------------- END READING TAG -----------------------------\\
        // ----------------- FIRST TAG ---------------\\
        if(strcmp(code, tag) == 0) {
          digitalWrite(2, HIGH);
          sound1();
          servo1();
          blink();
          delay(2000);
          digitalWrite(2, LOW);
        // -------------- END FIRST TAG ---------------\\
        //-----------------------2ND TAG -------------\\
        if(strcmp(code, tag_2) == 0) {
          digitalWrite(2, HIGH);        // deactivate reading
          sound1();                     // make a melody (see below)
          servo1();                     // unlock (see below)
          blink();                      // light flashes (see below)
          delay(2000);                    // wait before second reading
          digitalWrite(2, LOW);           // activate the device again
        //----------------- END 2ND TAG -------------\\
        //------------- if tag is wrong -------------\\
        else {
          sound2();                   // make a melody (see below)
          blink2();                   // light flashes (see below)
          delay(1000);                   // wait before second reading
        //------------- END if tag is wrong -------------\\
      bytesread = 0;                    // clear memory
      delay(500);                // wait for a second
//--------------------- END RFID reading and validation ---------------\\
void blink() {
  digitalWrite(ledPin2, HIGH);
  delay(100);
  digitalWrite(ledPin2, LOW);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
  delay(100);
void blink2() {
// ------------AUDIO--------------
void sound1(){
  for (int i = 0; i < length; i++) {
    if (notes[i] == ' ') {
      delay(beats[i] * tempo);
    else {
      playNote(notes[i], beats[i] * tempo);
    delay(tempo / 2);
// ------------AUDIO 2--------------
void sound2(){
    if (notes_2[i] == ' ') {
    else {
      playNote(notes_2[i], beats[i] * tempo);
    delay(tempo / 2);
// ------------END AUDIO 2--------------
void servo1(){
  myservo.write(100);
  delay(2000);
  myservo.write(0);
I was hoping you guys (and girls ;)) could help me out a bit :-/
What this message is really saying is that the compiler didn't recognize something before the = on the line that is causing the error.
I was able to get your code to compile by removing all the "\" at the ends of some of the comments.
Ok, so what you're saying is that the "\" disturbs the comment and acts like a part of the script that needs to be excecuted? I didn't know that. Man, do I feel stupid :-/
Thanks Paul!
It’s working like train :wink:
The "\" certainly shouldn't cause problems. They are part of a comment.
However, removing them allows the compiler to compile the code. So, clearly they DO cause problems. The simple solution is "Don't do that!".
The '\' is the line-continuation character. You're making more things part of the comment than you want to.
In basic, maybe. There ain't no such thing in C, C++, or C#.
Hah!
// I promise that the next line won't error \
#error
// Convinced?
void setup ()
void loop ()
