Code:
#include <Arduino_FreeRTOS.h>
// define two tasks for Blink & AnalogRead with the potentiometer
void TaskBlink( void *pvParameters );
void TaskAnalogRead( void *pvParameters );
// the setup function runs once when you press reset or power the board
// Now set up two tasks to run independently.
xTaskCreate(
TaskBlink
, (const portCHAR *)"Blink" //A name for the LED
, 128 // Stack size
, NULL
, 2 // priority
, NULL );
xTaskCreate(
TaskAnalogRead
, (const portCHAR *) "AnalogRead"
, 128 // This stack size can be checked & adjusted by reading Highwater
, NULL
, 1 // priority
, NULL );
// Now the task scheduler, which takes over control of scheduling individual tasks, is automatically started.
// Empty. Things are done in Tasks.
/---------------------- Tasks ---------------------/
void TaskBlink(void *pvParameters) // This is a task.
(void) pvParameters;
// initialize digital pin 13 as an output.
pinMode(13, OUTPUT);
for (; // A Task shall never return or exit.
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
vTaskDelay( 1000 / portTICK_PERIOD_MS ); // wait for one second
digitalWrite(13, LOW); // turn the LED off by making the voltage LOW
void TaskAnalogRead(void *pvParameters) // This is a task.
// initialize serial communication at 9600 bits per second:
for (;
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// print out the value you read:
Serial.println(sensorValue);
vTaskDelay(10); // one tick delay (150ms) in between reads for stability
Error Messages:
Arduino: 1.8.10 (Windows 10), Board: "Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)"
C:\Users\willi\OneDrive\Documents\Arduino\RTOS_LED_Potentiometer_Cide\RTOS_LED_Potentiometer_Cide.ino: In function 'void setup()':
RTOS_LED_Potentiometer_Cide:12:9: error: expected primary-expression before 'const'
RTOS_LED_Potentiometer_Cide:12:9: error: expected ')' before 'const'
RTOS_LED_Potentiometer_Cide:20:9: error: expected primary-expression before 'const'
RTOS_LED_Potentiometer_Cide:20:9: error: expected ')' before 'const'
Multiple libraries were found for "Arduino_FreeRTOS.h"
Used: C:\Users\willi\OneDrive\Documents\Arduino\libraries\FreeRTOS
exit status 1
option enabled in File -> Preferences.
