[Solved]Error in reading Analog values from two different ADC channels.
I made a circuit to resolve another member' problem. But I am observing an anomaly in that.
Board : Arduino on Breadboard This is the Sketch:
int val1,val2;
  val1 = analogRead(0);
  val2 = analogRead(1);
  delay(200);
  Serial.print("A0 = ");
  Serial.print(val1);
  Serial.print("\tA1 = ");
  Serial.println(val2);
I have used a voltage divider with two 10KOhm resistors across VCC and Gnd. A0 is connected to VCC and A1 is connected to the junctions of resistors(i.e. 2.5V).
I am getting
A0 = 1023 A1 = 824 (instead of 512 or near) the A1 value is slowly increasing.
I also checked the voltage at A1 Pin of the MCU and I am getting 2.5V in the multimeter.
Hey, I did not get that you did this for help me! thanks!
anyway I often get values around 800 (with 10-bit resolution) when the pin is floating!
It seems a common problem.So I gave it a try :)
Sorry the problem is resolved. @mbin you gav me the right hint, thanks.
I found the Problem.The MCU didn't sit right on the breadboard so it was floating.
