[Solved] ERROR: Library can't use both 'src' and 'utility' folders.
Hello,
I keep getting the following Error, as soon as I add the Wire.h Library:
Library can't use both 'src' and 'utility' folders. Double check /home/admin/builder/arduino-builder/packages/cores/arduino/avr/libraries/Wire
Happens on multiple PCs, with Firefox and Chrome
Is there any Solution for this?
Thank you
Hi @XStyhler, another user has the same error: thread here
hi if there any solution of this error i get this error in 1.8.5 versin
@sachinkangane1995
This is the ONLINE EDITOR are you sure you are in the correct section ?
