[solved]error message confusion
Hi all,
I am encountering an error message I do not understand, can anyone point me in the right direction, I cant see anything wrong.
The error message is :- /home/ross/sketchbook/libraries/MenuBackend/MenuBackend.h:195: error: stray ‘\342’ in program
/home/ross/sketchbook/libraries/MenuBackend/MenuBackend.h:195: error: stray ‘\200’ in program
/home/ross/sketchbook/libraries/MenuBackend/MenuBackend.h:195: error: stray ‘\250’ in program
Here is my code :-
#include <MAX6675.h>
#include <MenuBackend.h> //MenuBackend library - copyright by Alexander Brevig
//#include <LiquidCrystal.h> //this library is included in the Arduino IDE
#include <Wire.h>
#include <PID_v1.h>
#define RelayPin 7
//Define Variables we'll be connecting to
double Setpoint, Input, Output;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint,1600,10,10, DIRECT);
int WindowSize = 5000;
unsigned long windowStartTime;
int LED1 = 9; // Status LED Pin
int CS = 10; // CS pin on MAX6675
int SO = 12; // SO pin of MAX6675
int SCK = 13; // SCK pin of MAX6675
int units = 2; // Units to readout temp (0 = raw, 1 = ?C, 2 = ?F)
float temperature = 0.0; // Temperature output variable
// Initialize the MAX6675 Library for our chip
MAX6675 temp(CS,SO,SCK,units);
const int buttonPinLeft = 3; // pin for the Up button
const int buttonPinRight = 2; // pin for the Down button
const int buttonPinEsc = 5; // pin for the Esc button
const int buttonPinEnter = 4; // pin for the Enter button
int lastButtonPushed = 0;
int lastButtonEnterState = LOW; // the previous reading from the Enter input pin
int lastButtonEscState = LOW; // the previous reading from the Esc input pin
int lastButtonLeftState = LOW; // the previous reading from the Left input pin
int lastButtonRightState = LOW; // the previous reading from the Right input pin
long lastEnterDebounceTime = 0; // the last time the output pin was toggled
long lastEscDebounceTime = 0; // the last time the output pin was toggled
long lastLeftDebounceTime = 0; // the last time the output pin was toggled
long lastRightDebounceTime = 0; // the last time the output pin was toggled
long debounceDelay = 300; // the debounce time
LiquidCrystal_I2C lcd(0x27,16,2); // set the LCD address to 0x27 for a 16 chars and 2 line display
//Menu variables
MenuBackend menu = MenuBackend(menuUsed,menuChanged);
//initialize menuitems
MenuItem menu1Item1 = MenuItem("SetPoint");
MenuItem menuItem1SubItem1 = MenuItem("195");
MenuItem menuItem1SubItem2 = MenuItem("196");
MenuItem menuItem1SubItem3 = MenuItem("197");
MenuItem menuItem1SubItem4 = MenuItem("198");
MenuItem menuItem1SubItem5 = MenuItem("199");
MenuItem menuItem1SubItem6 = MenuItem("200");
MenuItem menuItem1SubItem7 = MenuItem("201");
MenuItem menuItem1SubItem8 = MenuItem("202");
MenuItem menuItem1SubItem9 = MenuItem("203");
/* MenuItem menu1Item2 = MenuItem("PID");
MenuItem menuItem2SubItem1 = MenuItem("P+");
MenuItem menuItem2SubItem2 = MenuItem("P-");
MenuItem menuItem2SubItem3 = MenuItem("I+");
MenuItem menuItem2SubItem4 = MenuItem("I-");
MenuItem menuItem2SubItem5 = MenuItem("D+");
MenuItem menuItem2SubItem6 = MenuItem("D-");
MenuItem menuItem3SubItem3 = MenuItem("Item2SubItem3");
MenuItem menu1Item3 = MenuItem("I");
MenuItem menuItem3SubItem1 = MenuItem("I+");
MenuItem menuItem3SubItem2 = MenuItem("I-");
MenuItem menu1Item4 = MenuItem("D");
MenuItem menuItem4SubItem1 = MenuItem("D+");
MenuItem menuItem4SubItem2 = MenuItem("D-");
pinMode(buttonPinLeft, INPUT);
pinMode(buttonPinRight, INPUT);
pinMode(buttonPinEnter, INPUT);
pinMode(buttonPinEsc, INPUT);
windowStartTime = millis();
//initialize the variables we're linked to
Setpoint = 109;
//tell the PID to range between 0 and the full window size
myPID.SetOutputLimits(0, WindowSize);
//turn the PID on
myPID.SetMode(AUTOMATIC);
lcd.init(); // initialize the lcd
lcd.backlight();
pinMode(LED1, OUTPUT); //thermocouple status
//configure menu
menu.getRoot().add(menu1Item1);
menu1Item1;//.addRight(menu1Item2); //.addRight(menu1Item3);
menu1Item1.add(menuItem1SubItem1).addRight(menuItem1SubItem2).addRight(menuItem1SubItem3).addRight(menuItem1SubItem4).addRight(menuItem1SubItem5).addRight(menuItem1SubItem6).addRight(menuItem1SubItem7).addRight(menuItem1SubItem8).addRight(menuItem1SubItem9);
//menu1Item2.add(menuItem2SubItem1).addRight(menuItem2SubItem2).addRight(menuItem2SubItem3).addRight(menuItem2SubItem4).addRight(menuItem2SubItem5).addRight(menuItem2SubItem6); //.addRight(menuItem3SubItem3);
//menu1Item3.add(menuItem3SubItem1).addRight(menuItem3SubItem2);
//menu1Item4.add(menuItem4SubItem1).addRight(menuItem4SubItem2);
menu.toRoot();
lcd.setCursor(0,0);
lcd.print("SV");
lcd.setCursor(2,0);
lcd.print( Setpoint );
} // setup()...
// Read the temp from the MAX6675
temperature = (temp.read_temp());
if(temperature < 0) {
// If there is an error with the TC, temperature will be < 0
lcd.setCursor(0,0);
lcd.print("Thermocouple Error on CS");
lcd.println( temperature );
digitalWrite(LED1, HIGH);
lcd.setCursor(8,0);
lcd.print("PV");
lcd.setCursor(10,0);
lcd.print( temperature );
/* lcd.setCursor(5,0);
lcd.print(" ");
lcd.setCursor(0,1); */
//lcd.print("SV:");
/* lcd.println( Setpoint );
lcd.setCursor(5,1);
lcd.print(" "); */
digitalWrite(LED1, LOW);
Input = temperature;
myPID.Compute();
* turn the output pin on/off based on pid output
unsigned long now = millis();
if(now - windowStartTime>WindowSize)
{ //time to shift the Relay Window
windowStartTime += WindowSize;
if(Output > now - windowStartTime) digitalWrite(RelayPin,HIGH);
else digitalWrite(RelayPin,LOW);
readButtons(); //I split button reading and navigation in two procedures because
navigateMenus(); //in some situations I want to use the button for other purpose (eg. to change some settings)
} //loop()...
and the rest of the code :-
void menuChanged(MenuChangeEvent changed){
MenuItem newMenuItem=changed.to; //get the destination menu
lcd.setCursor(0,1); //set the start position for lcd printing to the second row
if(newMenuItem.getName()==menu.getRoot()){
lcd.print("Menu ");
}else if(newMenuItem.getName()=="SetPoint"){
lcd.print("Change Setpoint");
}else if(newMenuItem.getName()=="195") {
Setpoint=195;
lcd.clear();
lcd.print("SV");
}else if(newMenuItem.getName()=="196") {
Setpoint=196;
lcd.clear();
lcd.print("SV");
}else if(newMenuItem.getName()=="197") {
Setpoint=197;
lcd.clear();
lcd.print("SV");
}else if(newMenuItem.getName()=="198") {
Setpoint=198;
lcd.clear();
lcd.print("SV");
}else if(newMenuItem.getName()=="199") {
Setpoint=199;
lcd.clear();
lcd.print("SV");
}else if(newMenuItem.getName()=="200") {
Setpoint=200;
lcd.clear();
lcd.print("SV");
}else if(newMenuItem.getName()=="201") {
Setpoint=201;
lcd.clear();
lcd.print("SV");
}else if(newMenuItem.getName()=="202") {
Setpoint=202;
lcd.clear();
lcd.print("SV");
}else if(newMenuItem.getName()=="203") {
Setpoint=203;
lcd.clear();
lcd.print("SV");
void menuUsed(MenuUseEvent used) {
/*lcd.setCursor(0,0);
lcd.print("You used ");
//lcd.print(used.item.getName());
//delay(2000); //delay to allow message reading
//lcd.setCursor(0,0);
//lcd.print("SP");
// lcd.setCursor(2,0);
//lcd.print( Setpoint );
menu.toRoot(); //back to Main
void readButtons(){ //read buttons status
int reading;
int buttonEnterState=LOW; // the current reading from the Enter input pin
int buttonEscState=LOW; // the current reading from the input pin
int buttonLeftState=LOW; // the current reading from the input pin
int buttonRightState=LOW; // the current reading from the input pin
//Enter button
// read the state of the switch into a local variable:
reading = digitalRead(buttonPinEnter);
// check to see if you just pressed the enter button
// (i.e. the input went from LOW to HIGH), and you've waited
// long enough since the last press to ignore any noise:
// If the switch changed, due to noise or pressing:
if (reading != lastButtonEnterState) {
// reset the debouncing timer
lastEnterDebounceTime = millis();
if ((millis() - lastEnterDebounceTime) > debounceDelay) {
// whatever the reading is at, it's been there for longer
// than the debounce delay, so take it as the actual current state:
buttonEnterState=reading;
lastEnterDebounceTime=millis();
// save the reading. Next time through the loop,
// it'll be the lastButtonState:
lastButtonEnterState = reading;
//Esc button
reading = digitalRead(buttonPinEsc);
// check to see if you just pressed the Down button
if (reading != lastButtonEscState) {
lastEscDebounceTime = millis();
if ((millis() - lastEscDebounceTime) > debounceDelay) {
buttonEscState = reading;
lastEscDebounceTime=millis();
lastButtonEscState = reading;
//Down button
reading = digitalRead(buttonPinRight);
if (reading != lastButtonRightState) {
lastRightDebounceTime = millis();
if ((millis() - lastRightDebounceTime) > debounceDelay) {
buttonRightState = reading;
lastRightDebounceTime =millis();
lastButtonRightState = reading;
//Up button
reading = digitalRead(buttonPinLeft);
if (reading != lastButtonLeftState) {
lastLeftDebounceTime = millis();
if ((millis() - lastLeftDebounceTime) > debounceDelay) {
buttonLeftState = reading;
lastLeftDebounceTime=millis();;
lastButtonLeftState = reading;
//records which button has been pressed
if (buttonEnterState==HIGH){
lastButtonPushed=buttonPinEnter;
}else if(buttonEscState==HIGH){
lastButtonPushed=buttonPinEsc;
}else if(buttonRightState==HIGH){
lastButtonPushed=buttonPinRight;
}else if(buttonLeftState==HIGH){
lastButtonPushed=buttonPinLeft;
}else{
lastButtonPushed=0;
void navigateMenus() {
MenuItem currentMenu=menu.getCurrent();
switch (lastButtonPushed){
case buttonPinEnter:
if(!(currentMenu.moveDown())){ //if the current menu has a child and has been pressed enter then menu navigate to item below
menu.use();
}else{ //otherwise, if menu has no child and has been pressed enter the current menu is used
menu.moveDown();
case buttonPinEsc:
menu.toRoot(); //back to main
case buttonPinRight:
menu.moveRight();
case buttonPinLeft:
menu.moveLeft();
lastButtonPushed=0; //reset the lastButtonPushed variable
and the backend :-
lcd.print("Menu ");
Setpoint=195;
lcd.clear();
lcd.print("SV");
Setpoint=196;
lcd.clear();
lcd.print("SV");
Setpoint=197;
lcd.clear();
lcd.print("SV");
Setpoint=198;
lcd.clear();
lcd.print("SV");
Setpoint=199;
lcd.clear();
lcd.print("SV");
Setpoint=200;
lcd.clear();
lcd.print("SV");
Setpoint=201;
lcd.clear();
lcd.print("SV");
Setpoint=202;
lcd.clear();
lcd.print("SV");
Setpoint=203;
lcd.clear();
lcd.print("SV");
//lcd.print("SP");
int reading;
//Enter button
//Esc button
//Down button
//Up button
}else{
lastButtonPushed=0;
menu.use();
menu.moveDown();
case buttonPinEsc:
menu.moveRight();
case buttonPinLeft:
menu.moveLeft();
Is that MenuBackend.h? It doesn't look like a .h file.
you have most probably copied unicode text into an ascii document.
### is an octal character code
open in notepad and if text looks fine, save-as as ansi text document then rename to .cpp, or .h or whatever it was before
Hi guys, thanks for your replies!
I have just switched to Ubuntu 10.04 (netbook remix).
I have been trying to use tofrodos to convert from the file to something ubuntu will use, but to no avail. Any pointers on how to make this work?
I have figured it out now. I learned a valuable lesson, that when adding a void function, the positioning of the void on the line matters.
