[SOLVED] Error while doing int to string
Hello Guys,
I am sorry if this is a dumb question but I cant explain this behavior.
When I am trying to convert from int to String its stops at 100 then as you reach 120 it returns 122, 130->133.
This is the code.
  for(int a=95;a<999;a++)
    Serial.print("Counter:");
    Serial.println(a);
    Serial.print("String:");
    Serial.println(String(a));
And this is the output.
Counter:95
String:95
Counter:96
String:96
Counter:97
String:97
Counter:98
String:98
Counter:99
String:99
Counter:100
String:100
Counter:101
String:100
Counter:102
String:100
Counter:103
String:100
If I do the following change it works.
    Serial.println(a);
    Serial.println(String(a+0.0));
Result
Counter:95
String:95.00
Counter:96
String:96.00
Counter:97
String:97.00
Counter:98
String:98.00
Counter:99
String:99.00
Counter:100
String:100.00
Counter:101
String:101.00
Counter:102
String:102.00
Counter:103
String:103.00
Counter:104
String:104.00
I get that It must be a expected behavior but I have been unable to understand why.
Your original code works OK for me
Windows 10
IDE 1.8.10
The real question is, why would you ever convert from an int to a String ?
Thank you for the answer, I have the same
Win 10
IDE 1.8.11
This is part of a larger program that uses an code input like "123A" on a switch case to execute several different functions.
I was running a debug run going thru all possible codes when I noticed that 101~109 was getting turned into 100.
I have another board at home I will try the same code on another board.
UKHeliBob:
Windows 10
IDE 1.8.10
What board are you using?
Pieter
The original problem was on a standalone atmega328p-pu, that was programed using a Arduino UNO.
I tested with Arduino Duemilanove, and the problem didn't occurred.
I tested with the Arduino UNO original chip and the problem didn't occurred.
I placed the atmega328p-pu again on the Arduino UNO board and problem was fixed.
Problem is solved. I don't know what happened.
PieterP:
Pieter
It is still not clear why that involves converting an int to a String
