Hi.
I'm developing a monitoring system which will collect some information and send it to my server via Wi-Fi.
I'll use arduino mega, ESP-01 and WiFiEsp library.
I've no problem with wiring and code, I'm able to send all required information to the server (it receives all data) but there is a trouble with the server response.
Currently I'm using node js + express as a dev server and it returns simple string to each request but using WiFiEsp I'm unable to get this response.
Then I've tried to send GET requests to different sites and find out that I could get request only from a small part of these servers.
#include "WiFiEsp.h"
#define HAVE_HWSERIAL1
// Emulate Serial1 on pins 6/7 if not present
#ifndef HAVE_HWSERIAL1
#include "SoftwareSerial.h"
SoftwareSerial Serial1(6, 7); // RX, TX
#endif
char ssid[] = "xxxx"; // your network SSID (name)
char pass[] = "xxxx"; // your network password
int status = WL_IDLE_STATUS; // the Wifi radio's status
char server[] = "arduino.ua";
// Initialize the Ethernet client object
WiFiEspClient client;
// initialize serial for debugging
// initialize serial for ESP module
Serial1.begin(115200);
// initialize ESP module
WiFi.init(&Serial1);
// check for the presence of the shield
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue
while (true);
// attempt to connect to WiFi network
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to WPA SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network
status = WiFi.begin(ssid, pass);
// you're connected now, so print out the data
Serial.println("You're connected to the network");
printWifiStatus();
Serial.println("Starting connection to server...");
// if you get a connection, report back via serial
if (client.connect(server, 80)) {
Serial.println("Connected to server");
// Make a HTTP request
client.println("GET / HTTP/1.1");
client.println("Host: arduino.ua");
client.println("Connection: close");
client.println();
// if there are incoming bytes available
// from the server, read them and print them
while (client.available()) {
char c = client.read();
Serial.write(c);
// if the server's disconnected, stop the client
if (!client.connected()) {
Serial.println("Disconnecting from server...");
client.stop();
// do nothing forevermore
while (true);
void printWifiStatus()
// print the SSID of the network you're attached to
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength
long rssi = WiFi.RSSI();
Serial.print("Signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
Response
[WiFiEsp] Initializing ESP module
[WiFiEsp] Initilization successful - 1.5.4
Attempting to connect to WPA SSID: XXXX
[WiFiEsp] Connected to XXXX
SSID: XXXX
IP Address: 192.168.0.100
Signal strength (RSSI):-622 dBmStarting connection to server...
[WiFiEsp] Connecting to arduino.ua
Connected to server
HTTP/1.1 200 OK
Date: Tue, 09[WiFiEsp] TIMEOUT: 1422
As you can see it is only a part of the server response..
In the same time I can get full response from servers: itc.ua, www.tecposter.com and probably some other.
Could you suggest some solution?
