(SOLVED) ESP32 Wifi not seen by phones - ELEGOO Smart Robot Car v4
My son and I assembled an ELEGOO Smart Robot Car v4, which includes a wifi camera (ESP32?). The wifi does not appear on any of our 3 phones, all of which are Samsung. However, my laptop can connect and receive video stream from it.
When I connected the controller to my laptop's serial, it returned the following output, which is an indication of diagnostics passing:
wifi_name:ELEGOO-xxxxxxxx
Starting web server on port: '80'
Starting stream server on port: '81'
Camera Ready! Use 'http://192.168.4.1' to connect
Elegoo-2020...
dhcps: send_offer>>udp_sendto result 0
The wifi uses the 2.4GHz band, and is open/unsecured. I thought maybe these were factors, but I've been unable to find any information that would indicate that Samsung/Android would have problems with either.
The issue is not a factor of any other portion of the car, because I had the same results while it was disconnected from the car.
Any ideas?
Side comment: I was impressed with the quality of the camera. While playing with it on my laptop, it was returning crisp video as high as 1920x1200, I believe. Of course, the higher the resolution, the lower the frame rate. I figured a "toy" camera would maybe go as high as 1024x768.
RESOLVED ... after some late-night sleuthing. It shouldn't have been this hard.
My setup: Linux Mint Debian Edition 5, Arduino IDE 1.8.13
Steps I took to resolve issues I encountered:
  1. Per the document found here: Camera module FAQ.pdf - Google Drive, I downloaded the ESP32_CameraServer arduino source. In step 5 of the document, where it recommends to select esp32 v. 1.0.4, I instead selected 1.0.6. In step 6 of the document, I randomly selected the source in channel 9.
  2. Upon attempt to compile, I got an error that it could not find esp_camera.h.
    In file included from ...path_to_source.../program for camera module/channel 9/ESP32_CameraServer_AP_20220120/ESP32_CameraServer_AP_20220120.ino:10:0: CameraWebServer_AP.h:12:24: fatal error: esp_camera.h: No such file or directory #include "esp_camera.h" ^ compilation terminated. exit status 1 esp_camera.h: No such file or directory
    This was resolved by ensuring all settings detailed in step 8 of the previous document were selected.
    Namely: Setting Board = "ESP32 Dev Module", Partition Scheme = "Huge APP (3MB No OTA/1MB SPIFFS)", PSRAM = "Enabled"
  3. Compile error related to python PATH
    exec: "python": executable file not found in $PATH on Arduino IDE
    Resolved following the solution found here: macos - exec: "python": executable file not found in $PATH on Arduino IDE - Stack Overflow
    where I needed to execute sed -i -e 's/=python /=python3 /g' ~/Library/Arduino15/packages/esp32/hardware/esp32/*/platform.txt.
    Another solution might be to create a symlink: ln -s /usr/bin/python3 /usr/bin/python
  4. And yet another compiler error, related to python: ModuleNotFoundError: No module named ‘serial’. Solution found here: https://forum.arduino.cc/t/modulenotfounderror-no-module-named-serial. In my case, not being a python developer, I had to install pip (sudo apt install pip) before I could execute the solution: sudo pip3 install pyserial.
After all that, my phone was able to connect to the camera, and I could control with the EleRobot app.
Nice follow-up. Hopefully that will help others in the future.
Now you and your son can have fun with your car.
It's amazing how often it helps just to tell about an issue and then finding the solution Yourself.
All the best.
That is why I have an extensive collection of rubber ducks
Any collaborator, discussion partner, inspiring is an asset.
Thanks guys. I believe in the sharing of knowledge, so when I solve a problem, I will often share the solution as I applied it.
This is obviously not a rare issue, though I'm sure certain conditions need to be present, such as device types and software revisions. I really wonder how many people have had this issue, and were unable to resolve it due to the technical skills required.
