I'm trying to setup an Adafruit HUZZAH ESP8266 breakout board with the ESP8266-FastLED-IoT-Webserver project. I've managed to follow the steps through step 3.1, where the software is uploaded to the board. The upload seems to work, however when I attempt the next step to upload the sketch data, I get the following error:
Connecting........_____....._____....._____....._____....._____....._____....._____
Traceback (most recent call last):
File "C:\Users\Mark\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\3.0.2\tools\upload.py", line 66, in <module>
esptool.main(cmdline)
File "C:/Users/Mark/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 3552, in main
esp.connect(args.before, args.connect_attempts)
File "C:/Users/Mark/AppData/Local/Arduino15/packages/esp8266/hardware/esp8266/3.0.2/tools/esptool\esptool.py", line 529, in connect
raise FatalError('Failed to connect to %s: %s' % (self.CHIP_NAME, last_error))
esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header
SPIFFS Upload failed!
I've been searching online for a fix, however fix I've attempted hasn't made it past this step. So far, I've tried the following:
Verified I'm using the correct serial port (COM4, which is only present while my board is connected to my computer via USB)
Change the esp8266 package version in Boards Manager (I've tried 3.0.2, 3.0.0, 2.7.2, 2.6.2, 2.5.2, and 2.5.0)
Re-installed the esp8266fs.jar file in the sketchbook tools, making sure to use the 0.5.0 version
Verified my python version (3.7.2)
I'm not finding many other options online, so I'm hoping someone here will be able to suggest another option. Any suggestions will be greatly appreciated.
Your topic was MOVED to its current forum category as it is more suitable than the original as it has noting to do with installation and troubleshooting of the IDE
What is your setup? Windows, mac?
Were you able to do uploads before without trouble?
What has changed since then?
Can you upload to other types of board like UNO?
Do you have a full USB cable (not one that can only charge)?
I work with another type of uploader (it uploads program and data in one go).
Did you reserve SPIFF space on the ESP?
In my version you need to set the size of the SPIFF.
Can you get a program that does not use SPIFF to work (i.e. a hello world or blink program).
I hope someone else has experience with your method and can get you further..
I managed to find a solution to this. Turns out, the data uploader I was using requires resetting the device and putting it back into bootloader mode between uploading the sketch and uploading the data. Didn't see anywhere mention this until I stumbled across a note halfway down on this page
