Under the custom tab of Libraries, when I am adding a library, the examples of that library are supposed to show up in the Examples section, under the 'From Libraries' tab, but there I can only see the examples of the default libraries, not those of the library I just installed.
Anybody noticed this? Please check it out and reply.
Thank you for your report @Rajduino, it is a known bug, if you refresh the page you should be seeing the Examples everywhere (in the Library tab and in the Examples from Library tab).
Let us know if this is the case for you too, best!
Thought I had the same issue but...
Seems its maybe the same as the regular IDE.
Once I restarted the web IDE they were there.
An F5 refresh on Win7 x64 in Chrome didn't do it had to close and re-open page.
UPDATE
I don't have to close the IDE any more I just clicked in the left pane "Libraries" and then clicked it again to open up the libs page.
Yes we know about this bug and will solve it in the near future! Just refresh the page and the examples for custom libraries will show up ![]()
Thanks for your report
this issue has been solved and now examples show up right away, thanks for your report and let us know if you still encounter this issue!
