[Solved]expected identifier before numeric constant when instantiating object...
The rest of the library:
nokia5110.cpp
This file contains the functions and data required
to drive several Nokia 5110 LCD displays.
#include "nokia5110.h"
#include "Arduino.h"
nokia5110::nokia5110(int SCE, int RESET, int DC, int SDIN, int SCLK)
  //Set up the pins
  pinMode(SCE,   OUTPUT);
  pinMode(RESET, OUTPUT);
  pinMode(DC,    OUTPUT);
  pinMode(SDIN,  OUTPUT);
  pinMode(SCLK,  OUTPUT);
  //Reset the display
  digitalWrite(RESET, LOW);
  digitalWrite(RESET, HIGH);
  LcdWrite(0, 0x21);  // LCD Extended Commands.
  LcdWrite(0, 0xBf);  // Set LCD Vop (Contrast). //B1
  LcdWrite(0, 0x04);  // Set Temp coefficent. //0x04
  LcdWrite(0, 0x14);  // LCD bias mode 1:48. //0x13
  LcdWrite(0, 0x0C);  // LCD in normal mode. 0x0d for inverse
  LcdWrite(LOW, 0x20);
  LcdWrite(LOW, 0x0C);
  //Set the global variables
  _SCE = SCE;
  _RESET = RESET;
  _DC = DC;
  _SDIN = SDIN;
  _SCLK = SCLK;
  //Set up the ASCII tables
static byte ASCII[][5] = {
  {0x00, 0x00, 0x00, 0x00, 0x00} // 20
 ,{0x00, 0x00, 0x5f, 0x00, 0x00} // 21 !
 ,{0x00, 0x07, 0x00, 0x07, 0x00} // 22 "
 ,{0x14, 0x7f, 0x14, 0x7f, 0x14} // 23 #
 ,{0x24, 0x2a, 0x7f, 0x2a, 0x12} // 24 $
 ,{0x23, 0x13, 0x08, 0x64, 0x62} // 25 %
 ,{0x36, 0x49, 0x55, 0x22, 0x50} // 26 &
 ,{0x00, 0x05, 0x03, 0x00, 0x00} // 27 '
 ,{0x00, 0x1c, 0x22, 0x41, 0x00} // 28 (
 ,{0x00, 0x41, 0x22, 0x1c, 0x00} // 29 )
 ,{0x14, 0x08, 0x3e, 0x08, 0x14} // 2a *
 ,{0x08, 0x08, 0x3e, 0x08, 0x08} // 2b +
 ,{0x00, 0x50, 0x30, 0x00, 0x00} // 2c ,
 ,{0x08, 0x08, 0x08, 0x08, 0x08} // 2d -
 ,{0x00, 0x60, 0x60, 0x00, 0x00} // 2e .
 ,{0x20, 0x10, 0x08, 0x04, 0x02} // 2f /
 ,{0x3e, 0x51, 0x49, 0x45, 0x3e} // 30 0
 ,{0x00, 0x42, 0x7f, 0x40, 0x00} // 31 1
 ,{0x42, 0x61, 0x51, 0x49, 0x46} // 32 2
 ,{0x21, 0x41, 0x45, 0x4b, 0x31} // 33 3
 ,{0x18, 0x14, 0x12, 0x7f, 0x10} // 34 4
 ,{0x27, 0x45, 0x45, 0x45, 0x39} // 35 5
 ,{0x3c, 0x4a, 0x49, 0x49, 0x30} // 36 6
 ,{0x01, 0x71, 0x09, 0x05, 0x03} // 37 7
 ,{0x36, 0x49, 0x49, 0x49, 0x36} // 38 8
 ,{0x06, 0x49, 0x49, 0x29, 0x1e} // 39 9
 ,{0x00, 0x36, 0x36, 0x00, 0x00} // 3a :
 ,{0x00, 0x56, 0x36, 0x00, 0x00} // 3b ;
 ,{0x08, 0x14, 0x22, 0x41, 0x00} // 3c <
 ,{0x14, 0x14, 0x14, 0x14, 0x14} // 3d =
 ,{0x00, 0x41, 0x22, 0x14, 0x08} // 3e >
 ,{0x02, 0x01, 0x51, 0x09, 0x06} // 3f ?
 ,{0x32, 0x49, 0x79, 0x41, 0x3e} // 40 @
 ,{0x7e, 0x11, 0x11, 0x11, 0x7e} // 41 A
 ,{0x7f, 0x49, 0x49, 0x49, 0x36} // 42 B
 ,{0x3e, 0x41, 0x41, 0x41, 0x22} // 43 C
 ,{0x7f, 0x41, 0x41, 0x22, 0x1c} // 44 D
 ,{0x7f, 0x49, 0x49, 0x49, 0x41} // 45 E
 ,{0x7f, 0x09, 0x09, 0x09, 0x01} // 46 F
 ,{0x3e, 0x41, 0x49, 0x49, 0x7a} // 47 G
 ,{0x7f, 0x08, 0x08, 0x08, 0x7f} // 48 H
 ,{0x00, 0x41, 0x7f, 0x41, 0x00} // 49 I
 ,{0x20, 0x40, 0x41, 0x3f, 0x01} // 4a J
 ,{0x7f, 0x08, 0x14, 0x22, 0x41} // 4b K
 ,{0x7f, 0x40, 0x40, 0x40, 0x40} // 4c L
 ,{0x7f, 0x02, 0x0c, 0x02, 0x7f} // 4d M
 ,{0x7f, 0x04, 0x08, 0x10, 0x7f} // 4e N
 ,{0x3e, 0x41, 0x41, 0x41, 0x3e} // 4f O
 ,{0x7f, 0x09, 0x09, 0x09, 0x06} // 50 P
 ,{0x3e, 0x41, 0x51, 0x21, 0x5e} // 51 Q
 ,{0x7f, 0x09, 0x19, 0x29, 0x46} // 52 R
 ,{0x46, 0x49, 0x49, 0x49, 0x31} // 53 S
 ,{0x01, 0x01, 0x7f, 0x01, 0x01} // 54 T
 ,{0x3f, 0x40, 0x40, 0x40, 0x3f} // 55 U
 ,{0x1f, 0x20, 0x40, 0x20, 0x1f} // 56 V
 ,{0x3f, 0x40, 0x38, 0x40, 0x3f} // 57 W
 ,{0x63, 0x14, 0x08, 0x14, 0x63} // 58 X
 ,{0x07, 0x08, 0x70, 0x08, 0x07} // 59 Y
 ,{0x61, 0x51, 0x49, 0x45, 0x43} // 5a Z
 ,{0x00, 0x7f, 0x41, 0x41, 0x00} // 5b [
 ,{0x02, 0x04, 0x08, 0x10, 0x20} // 5c ¥
 ,{0x00, 0x41, 0x41, 0x7f, 0x00} // 5d ]
 ,{0x04, 0x02, 0x01, 0x02, 0x04} // 5e ^
 ,{0x40, 0x40, 0x40, 0x40, 0x40} // 5f _
 ,{0x00, 0x01, 0x02, 0x04, 0x00} // 60 `
 ,{0x20, 0x54, 0x54, 0x54, 0x78} // 61 a
 ,{0x7f, 0x48, 0x44, 0x44, 0x38} // 62 b
 ,{0x38, 0x44, 0x44, 0x44, 0x20} // 63 c
 ,{0x38, 0x44, 0x44, 0x48, 0x7f} // 64 d
 ,{0x38, 0x54, 0x54, 0x54, 0x18} // 65 e
 ,{0x08, 0x7e, 0x09, 0x01, 0x02} // 66 f
 ,{0x0c, 0x52, 0x52, 0x52, 0x3e} // 67 g
 ,{0x7f, 0x08, 0x04, 0x04, 0x78} // 68 h
 ,{0x00, 0x44, 0x7d, 0x40, 0x00} // 69 i
 ,{0x20, 0x40, 0x44, 0x3d, 0x00} // 6a j
 ,{0x7f, 0x10, 0x28, 0x44, 0x00} // 6b k
 ,{0x00, 0x41, 0x7f, 0x40, 0x00} // 6c l
 ,{0x7c, 0x04, 0x18, 0x04, 0x78} // 6d m
 ,{0x7c, 0x08, 0x04, 0x04, 0x78} // 6e n
 ,{0x38, 0x44, 0x44, 0x44, 0x38} // 6f o
 ,{0x7c, 0x14, 0x14, 0x14, 0x08} // 70 p
 ,{0x08, 0x14, 0x14, 0x18, 0x7c} // 71 q
 ,{0x7c, 0x08, 0x04, 0x04, 0x08} // 72 r
 ,{0x48, 0x54, 0x54, 0x54, 0x20} // 73 s
 ,{0x04, 0x3f, 0x44, 0x40, 0x20} // 74 t
 ,{0x3c, 0x40, 0x40, 0x20, 0x7c} // 75 u
 ,{0x1c, 0x20, 0x40, 0x20, 0x1c} // 76 v
 ,{0x3c, 0x40, 0x30, 0x40, 0x3c} // 77 w
 ,{0x44, 0x28, 0x10, 0x28, 0x44} // 78 x
 ,{0x0c, 0x50, 0x50, 0x50, 0x3c} // 79 y
 ,{0x44, 0x64, 0x54, 0x4c, 0x44} // 7a z
 ,{0x00, 0x08, 0x36, 0x41, 0x00} // 7b {
 ,{0x00, 0x00, 0x7f, 0x00, 0x00} // 7c |
 ,{0x00, 0x41, 0x36, 0x08, 0x00} // 7d }
 ,{0x10, 0x08, 0x08, 0x10, 0x08} // 7e ←
 ,{0x00, 0x06, 0x09, 0x09, 0x06} // 7f →
void nokia5110::LcdCharacter(char character) //Prints a charachter to the LCD
  LcdWrite(HIGH, 0x00);
  for (int index = 0; index < 5; index++)
    LcdWrite(HIGH, ASCII[character - 0x20][index]);
void nokia5110::LcdClear() //Blanks out the LCD
  for (int index = 0; index < 84 * 48
 / 8; index++)
void nokia5110::LcdString(char *characters) // Print a string to the LCD
  while (*characters)
    LcdCharacter(*characters++);
void nokia5110::LcdWrite(byte dc, byte data) // Send data to the LCD
  digitalWrite(_DC, dc);
  digitalWrite(_SCE, LOW);
  shiftOut(_SDIN, _SCLK, MSBFIRST, data);
  digitalWrite(_SCE, HIGH);
// gotoXY routine to position cursor
// x - range: 0 to 84
// y - range: 0 to 5
void nokia5110::gotoXY(int x, int y)
  LcdWrite(0, 0x80 | x);  // Column.
  LcdWrite(0, 0x40 | y);  // Row.
void nokia5110::drawBorderBox() // Print a line on the LCD
  unsigned char  j;
   for(j=0; j<84; j++) // top
    gotoXY (j,0);
	LcdWrite (1, 0x01);
  for(j=0; j<84; j++) //Bottom
    gotoXY (j,5);
	LcdWrite (1, 0x80);
  for(j=0; j<6; j++) // Right
    gotoXY (83,j);
	LcdWrite (1, 0xff);
	for(j=0; j<6; j++) // Left
    gotoXY (0,j);
	LcdWrite (1, 0xff);
And the compiler output:
nokia5110\nokia5110.cpp.o: In function `nokia5110::LcdCharacter(char)':
C:\Users\kuhnbe\Documents\Arduino\libraries\nokia5110/nokia5110.cpp:140: undefined reference to `nokia5110::ASCII'
C:\Users\kuhnbe\Documents\Arduino\libraries\nokia5110/nokia5110.cpp:141: undefined reference to `nokia5110::ASCII'
Thanks again.
