Basically, I have a variable of my struct-Definiton which contains some additional information regarding my actual (much bigger) code. The pointer RESULTS should hold small numbers (data from/ for a chip). This data will be filled using an method.
I read in some forums, that I should pass the array via the method and fill it using memcpy (filling by using the actual adress of the destination array).
In this example the output (hold:) produces just wrong values (probably points (!) to the wrong adress), where in my much bigger project the arduino just restarts (which usually happens when I do something very wrong with the memory allocation).
The only way you can have your array to fit different sizes is to do dynamic size. But dynamic memory is bad on low memory devices. So your best option is to make your array the biggest size you think it's gonna need
You are just copying data to a dangling pointer. All you're doing is corrupting your memory.
You have to understand that RESULTS, RES and arr are not arrays. They are all pointers.
You have to follow a different strategy.
Option 1: dynamically allocate memory for the local array, and initialize the RESULTS pointer with a pointer to that block of memory you just allocated. This is a terrible idea on a microcontroller, since you have to prevent heap fragmentation.
Option 2: save the data you need in static memory (or at least memory that has a longer lifetime than your Arrayholder), and just have the RESULTS pointer point to that memory.
Option 3: use fixed-size arrays for all of your data.
Do you realize that you are not copying the array? When you reach the end of the loop, arr goes out of scope, and your global struct SOLUTION is invalid, because SOLUTION.RESULTS is now a pointer to a variable that no longer exists. It'll probably work in a simple example, because you're lucky and the memory of arr is not re-used for other purposes, but the behavior of your program is undefined, and it will crash eventually.
First thing to note is that arr takes up 14 Bytes, and Mysolution is only 4 Bytes in size. There is no way that you can save 14 Bytes of data in 4 Bytes of storage, so sol can never contain a copy of your data.
It contains a boolean, an 8-bit integer, and a pointer, (1+1+2 = 4 Bytes).
Second thing to note is that there is no difference between the memcpy version, and the normal assignment copy version. The compiler generates a copy constructor for you, that copies all member variables for you. Using memcpy in this case is just asking for bugs.
The problems you're seeing with the code you didn't post are probably just problems with lifetime differences and danging pointers, as we've tried to tell you many times before.
void Myclass::seterMethod(uint8_t arr[], uint8_t ch) {
// fill array
implemented in a loop
TheClass VAR;
void AnotherClass::repeat(uint8_t ch) {
uint8_t temp[MAX_SIZE];
seterMethod(temp,ch);
// check if everything is alright with the array
Mysolution mysol = {true,MAX_SIZE,temp};
VAR.setData(&mysol); // use generated data wherever
I also filled the memory with unnecessary data to prevent accidentally accessing the 'right' part.
Currently running ~1h without any problems.
