SOLVED - Firmware update stuck
So I checked for update after getting wifi, update your firmware warnings. I made sure serial monitor is closed, only ONE project is open. I'm using the same cable that I upload sketches with which works very fast. It's been stuck on installing firmware and its still going... I see the LED pulsing on the board but... its been like 10 minutes.
Anyone else having issues updating firmware? I have the latest IDE, checked for updates. It's up to date.
SOLVED.... I had a macbook pro i do a lot of this on. That is where the firmware update kept hanging. I moved it to my PC and the firmware update worked. Must be an unfortunate bug in the IDE firmware update feature on mac. If it matters its an intel macbook pro, last fully loaded one before they switched to M chips.
Anyway.... use PC to update firmware I guess.
I can agree, this is still occuring with a mac pro - made an account just to say this
Switched to windows
  1. Downloaded Windows IDE 2.3.4
  2. Opened and accepted every driver and admin request
  3. Went to 'Boards' and searched r4 and downloaded Arduino Uno R4 Boards 1.3.2
  4. Connected Board and selected in the dropdown
  5. Tools > Firmware update was not showing board, after restart of application it showed
  6. Updated firmware in less then a minute
Back to Mac I go
Confirmed that this is actual an Intel Mac issue. I have a 2019 MacBook Pro (intel) that was experiencing this hanging. Work provides me an Apple Silicon MacBook Pro, so I thought I would try and upgrade the firmware on that machine. It worked, so it seems to be specific to intel mac's.
I am using a MacBook Pro (Retina, 13-inch, Late 2013), and as described in Use the Firmware Updater in Arduino IDE, if I close the serial monitor before running the update, it works correctly.
  1. Connect the board to your computer and open Arduino IDE 2.
  2. If the Serial Monitor is open, close it.
  3. In the top menu bar, open Tools > Firmware Updater.
