[Solved] Fixing Function to Decrement Place Value Variables
I am programming a simple counter, to increment and decrement with the push of respective buttons.
Why does ++ work with byte type variables, at least it seemed to work...?
Why does -- not work?
The documentation doesn't seem confident it works for unsigned data types.
I'd like to know what's going on under the hood so I can better understand the behavior of the bug...
-- works fine for both byte and char. Show us your evidence that it doesn't.
Are you going to supply any proof it does not work?
Paul
Delta_G: -- works fine for both byte and char. Show us your evidence that it doesn't.
Paul_KD7HB: Are you going to supply any proof it does not work?
Paul
Sorry my decrement function isn't working as expected, and I thought this was the problem... Clearly, it isn't. Here are both functions, for incrementing, and decrementing. The place values are separated to facilitate multiplexing an LED matrix.
void incrementCount() {
  if (unitCountOnes >= 9) {
    unitCountOnes = 0;
    if (unitCountTens >= 9) {
      unitCountTens = 0;
      if (unitCountHundreds >= 9) {
        unitCountHundreds = 0;
        if (unitCountThousands >= 9) {
          unitCountThousands = 0;
        else unitCountThousands++;
      else unitCountHundreds++;
    else unitCountTens++;
  else unitCountOnes++;
void decrementCount() {
  if (unitCountOnes = 0) {
    unitCountOnes = 9;
    if (unitCountTens = 0) {
      unitCountTens = 9;
      if (unitCountHundreds = 0) {
        unitCountHundreds = 9;
        if (unitCountThousands = 0) {
          unitCountThousands = 9;
        else unitCountThousands--;
      else unitCountHundreds--;
    else unitCountTens--;
  else unitCountOnes--;
If there's a problem with that code, I don't see it.
Suspect problem is elsewhere, in the code you haven't posted.
Ooops...
DrAzzy: If there's a problem with that code, I don't see it.
== vs = It took me a LONG while to see it too.
and what is the purpose of this code? computers can do numbers bigger then 9
I usually use something like:
// to count up
unitCountOnes++;
doCarries();
// to count down
unitCountThousands += 9;
unitCountHundreds += 9;
unitCountTens += 9;
UnitCountOnes += 9;
doCarries();
// to do the carries when counting in either direction
void doCarries() {
  if (unitCountOnes >= 10) {
    unitCountOnes -= 10;
    unitCountTens++;
  if (unitCountTens >= 10) {
    unitCountTens -= 10;
  if (unitCountHundreds >= 10) {
    unitCountHundreds -= 10;
  if (unitCountThousands >= 10) {
    unitCountThousands -= 10;
    // our counter has no higher digit to which to carry
I can't imagine what for are the unitCounts?
Juraj: I can't imagine what for are the unitCounts?
If you use 8-bit shift registers to multiplex 8 7-segment LEDs, you need a single value for each digit.
Wow.
How did I miss that.
Perehama: If you use 8-bit shift registers to multiplex 8 7-segment LEDs, you need a single value for each digit.
I would count the usual way and take apart the number for display
Juraj: I would count the usual way and take apart the number for display
If you could show me this in code, I would appreciate it. My own attempts to generate such code have resulted in division which consumes enough mcu processes to have a noticeable affect on the display refresh.
displaying is in interrupt? the countdown is in milliseconds? at least I would use array for the units
Juraj: displaying is in interrupt? the countdown is in milliseconds? at least I would use array for the units
It is not necessary to be so precise as an interrupt, I use non-blocking code and micros() timekeeping for the display refresh, which can vary a little as long as the human eye perceives the display is lit as a whole. The count is not time, but cardinal units. An array ends up less readable in code.
Simpler using array of digits, recursive carry function:
byte count_digit[4] ;
void increment (byte index = 0)
  if (index >= 4) // overflow top digit
    return ;
  if (count_digit[index] == 9)
    count_digit[index] = 0;
    increment (index+1) ;
    count_digit[index] ++ ;
// then to increment by one, call "increment()"
For fastest decode of int to decimal digits divide and conquer:
void decode_digits (unsigned int value)
  high_part = value / 100 ;
  low_part = value - 100 * high_part ;  // split into two small problems
  thousands = high_part / 10 ;
  hundreds = high_part - 10 * thousands ;
  tens = low_part / 10 ;
  units = low_part - 10 * tens ;
Note only 3 divisions, no remainders, and multiplies are done in hardware anyway, and the smaller divides can be done with table lookup if required for ultimate performance, leaving a single divide by 100.
You can do also better
void Operation (byte index, char addiction)
value [index%4]=(value[index%4]+(2*addiction-1))%9
I think it is what you want.
Addiction=0->-1
Addiction=1->+1
Silente: You can do also better
I think it is what you want. Addiction=0->-1 Addiction=1->+1
Addiction?? Besides, that code can't be right. Why the modulo 9 ?
MarkT: For fastest decode of int to decimal digits divide and conquer:
  thousands = high_part / 10 ;   hundreds = high_part - 10 * thousands ;   tens = low_part / 10 ;   units = low_part - 10 * tens ;
Or, you could get rid of the multiplications and divisions entirely.
int leftover = value_to_be_converted;
byte thou = 0;
byte hund = 0;
byte tens = 0;
byte ones = 0;
while (leftover >= 1000) { leftover -= 1000; thou++; }
while (leftover >=  100) { leftover -=  100; hund++; }
while (leftover >=   10) { leftover -=   10; tens++; }
ones = leftover;
