Solved for loop like basic?
Coding
The C for loop is much more flexible than for loops found in some other computer languages, including BASIC. Any or all of the three header elements may be omitted, although the semicolons are required.
OK, of so, how do I write an example like: In Basic: for i = x to y step z ? in one loop.
Any of the 3 values can be + or -, x can be > y or < y.
The a good design tip for micro controller programming is DON'T use for or while loops!. As for how to use a fro loop just look in the reference section.
Mark
The a good design tip for micro controller programming is DON’T use for or while loops!.
couldnt live without my for() loops…
not 100% sure what you mean, but like these?
  int j = -1;
  //leave out increminting for for() statement:
  for (int i = -4; i <= 10;)
    Serial.println(i);
    i++;
  Serial.println(" ");
  //leave out limit:
  for (int i = -4;;i++)
    Serial.println(i);
    if (i>10) break;
  //leave out initial value
  for(; j >= -10 ; j--)
    Serial.println(j);
  • or - Increminting should be automatic. Why specify ++ or -- The compiler should figure that out.
steinie44: or (int i = -4;;i++)
How is the compiler supposed to know to count up or count down? You may want a deliberate wrap.
By the sign of z.
This also works (I hope :slight_smile: )
for(int j = 21; j <= 70 ; j += 7)
…R
It does, I was doing the same
byte x;
byte a;
const byte blinkpin = 13;
void setup ()
  pinMode (blinkpin, OUTPUT);
void loop ()
  for(x=0; x < 10; x=x+2)
    digitalWrite(blinkpin, HIGH);
    Serial.println(x,DEC);
    digitalWrite(blinkpin, LOW);
  delay(2000);
holmes4: The a good design tip for micro controller programming is DON'T use for or while loops!. As for how to use a fro loop just look in the reference section.
Mark
Nope, I disagree. Writing pinModes for a Mega gets tedious, for one thing.
How about
for(i=x; i < y; i=i+z)
But what if x > y?
steinie44:
How about
But what if x > y?
The body of the loop doesn’t get executed, as expected and presumably intended.
What’s your point?
Mark
BS Try displaying a ASCII table without it. If they are not good design, then get rid of them.
So, are we done here?
I looked. Nothing on fro loops.
No
What’s your point?
Why?
Point is Reference, for, Coding Tips, is Not True.
Nothing stopping you from writing in BASIC, if that is really what you want.
What I want is a Single for loop to step a servo left or right with No if statements.
steinie44:
How about
But what if x > y?
steinie44:
No
What’s your point?
Why?
Why?
If x > y, i is also > y.
Why anyone would want to cripple C down to the level of BASIC is beyond me.
steinie44:
Ok, here’s my attempt:
for (i=x; z>0 ? i<=y : i>=y; i+=z)
steinie44:
How would you do that in Basic?
What about
int start = 0; // or 180
int end = 180;  // or 0
int step = 5;  // or -5
for (int n = start; n != end; N += step) {
   servo.write(n);
  delay(50);
…R
