Is there a way to have a for loop with two variables that it iterates through.
I want one variable to start at 15 and go down to 0. I want the other variable to start at 39 and go down to 22.
Simultaneously or one then the other or like each first variable increment runs all of the second ones each time or what?
for( int i = 15; i >= 0; i--)
for( int j = 39; j >= 22; j--)
Serial.print("(");
Serial.print(i);
Serial.print(",");
Serial.print(j);
Serial.print("), ");
I think you're asking for something that behaves like this:
int i;
int k;
i = 15;
for (k = 39; k > 21; k--) {
Serial.print("i = ");
Serial.print(i);
if (i != 0)
i--;
Serial.print(" k = ");
Serial.println(k);
You can do this:
for (int i = 15, j = 39; (i > 0) && (j > 22); i++, j--)
Regards,
Ray L.
i don't want nested if statements.
my code is:
for(int i = 9; i > -1; i--) {
digitalWrite(outputPin, bitRead(value, i));
outputPin = outputPin - 1;
I was hoping for a neater solution.
I am trying to do binary to decimal conversion and output it to an array of wires.
Your solution works fine. Thanks
Couldn't you just type dec before the binary value instead of converting yourself? I thought the Arduino knows the diff formats of the same value.
135843:
a total of 16 iterations
135843:
a total of 18 iterations.
How many times did you want the code in the loop to execute?
