SOLVED: FTP on NodeMCU - connection issues
I've built a datalogger to monitor the connections on my local area network.
All details here if anyone is interested.
My problem is that I use FTP to download data from the Node to my PC; however after running for a while (maybe months) the FTP refuses to connect.
I've shown the relevant bits of FTP handling here, but I've also attached the full code for context. The program is a state machine driven by millis(), and the only code I can see that could block is the "PerformPing" routine - which is only active for 7 seconds in every 60.
#include <ESP8266FtpServer.h>       //ftp server library
FtpServer ftpSrv;   //set #define FTP_DEBUG in ESP8266FtpServer.h to see ftp verbose on serial
  //monitor Wifi connection and handle D0
  gotIpEventHandler = WiFi.onStationModeGotIP([](const WiFiEventStationModeGotIP & event)
    //Serial.print("Station connected, IP: ");
    //Serial.println(WiFi.localIP());
    WiFiState = 1;
    digitalWrite(dPin[0], 0); //blue LED is active LOW
  disconnectedEventHandler = WiFi.onStationModeDisconnected([](const WiFiEventStationModeDisconnected & event)
    Serial.println("Station disconnected");
    WiFiState = 0;
    digitalWrite(dPin[0], 1); //blue LED OFF
  connectWiFi();
  //FTP Setup, ensure SPIFFS is started before ftp;
  if (SPIFFS.begin()) {
    Serial.println("SPIFFS opened!");
    ftpSrv.begin("esp8266", "esp8266");   //username, password for ftp.  set ports in ESP8266FtpServer.h  (default 21, 50009 for PASV)
  ftpSrv.handleFTP();        //make sure in loop you call handleFTP()!!
PerformPing
/*   code for pinging and led display  */
bool PerformPing()
  if (roundComplete)  //ready for next set of pings
    isFinished = false;
    int url = target;
    bool pingOK = pinger.Ping(IPAddress(host1[url].IP), pingNumber, pingTime);
    roundComplete = false;
  else if (isFinished)        // one set of pings to a single target complete and results in
    isFinished = false;
    //correct data: average is only correct if no pings lost; otherwise its the sum of the valid ping times
    if (pingsLost == 0) {
      host1[target].tPing = pingAvg;
    else {
      host1[target].tPing = int((pingAvg + pingsLost * pingTime) / pingNumber);
    host1[target].nLost = pingsLost;
    checkFailedPings();
    roundComplete = true;
  return roundComplete;
netmonitor.ino (20.5 KB)
Well, all by myself I have found the answer while working on a new project.
If the loop includes code that can take significant time the FTP fails. Presumably it just times out.
My sequence of pings must have been taking too long.
The sketch uses this library
and the example FTPServerSample.ino (code below) is VERY responsive - note the loop has no other code to slow it down.
#ifdef ESP8266
#include <ESP8266WiFi.h>
#elif defined ESP32
#include <WiFi.h>
#include "SPIFFS.h"
#endif
const char* ssid = "YOUR_SSID";
const char* password = "YOUR_PASS";
void setup(void){
  WiFi.begin(ssid, password);
  Serial.println("");
  // Wait for connection
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to ");
  Serial.println(ssid);
  Serial.print("IP address: ");
  /////FTP Setup, ensure SPIFFS is started before ftp;  /////////
#ifdef ESP32       //esp32 we send true to format spiffs if cannot mount
  if (SPIFFS.begin(true)) {
#elif defined ESP8266
#endif
      ftpSrv.begin("esp8266","esp8266");    //username, password for ftp.  set ports in ESP8266FtpServer.h  (default 21, 50009 for PASV)
void loop(void){
 // server.handleClient();   //example if running a webserver you still need to call .handleClient();
