I’m working on a geartooth sensor for a reloading press and having some coding issues. I’m sure it’s a simple fix but I’m new at this…
My sensor connected to a Uno on a digital pin works fine and gives a high/low value depending on the sprocket teeth position. If the value of the sensor doesn’t change for > 1sec… then the gear is not turning (a Jam occured) and the Uno will trigger a relay and cut power to the motor…
Here’s the code…It’s my first project. If someone could point out the obvious to me I’m a bit stuck and the more I tinker with the code the deeper I get…
Thanks in advance!!
Eric
int sensePin =2;
int relayPin =8;
void setup(){
pinMode(sensePin, INPUT);
Serial.println(digitalRead(sensePin));
currentValue = sensPin();
unsigned long timer = millis();
if(currentValue != oldValue && millis() - timer < 1000) // 1000 = 1 second
oldValue = currentValue; // they were different and values changed within 1 second, so update old value for next reading
Serial.println("Oscillating! "); // show a message that it was oscillating
timer = millis(); // Reset timer
if(millis() - timer >= 1000); //trigger relay if sensor value is constant for greater than 1 sec
digitalWrite(relayPin, HIGH); //turn on relay
// set an output pin high
sketch_oct25a.ino: In function 'void loop()':
sketch_oct25a:15: error: 'currentValue' was not declared in this scope
sketch_oct25a:15: error: 'sensPin' was not declared in this scope
sketch_oct25a:18: error: 'oldValue' was not declared in this scope
sketch_oct25a:29: error: expected `}' at end of input
Is that the issue that you are having? If not, where is the code that compiles, and what is the issue? What you've posted so far is like saying "my car won't start. It's red".
int sensePin =2; //gear sensor 5v
int relayPin =8;
void setup(){
int currentValue = (digitalRead(sensePin)); //should read the High/Low from sensor
I fixed currentvalue but I’m not sure how to handle old value…I’m trying to compare states of sensor and take action if state does not change for 1 sec…
The easiest way is to define a global variable, called oldValue. At the end of loop(), assign oldValue to value that is in currentValue.
Get rid of the delay() call at the top of loop.
timer is a lousy name for an interval. It needs to be a global variable, too, of type unsigned lomg.
Use Tools + Auto Format, and make more of an effort to keep the code properly indented.
I changed a few things and got the sketch to compile…I’m wanting to compare the oldvalue to the currentvalue of the sensor and take action if the state is not changing after 1 sec…
Can anyone see if my code will do this?
Thanks
Eric
int sensePin =2; //gear sensor 5v digital
int relayPin =8; //coil of micro relay to cut power
void setup(){
int oldValue =(digitalRead(sensePin)); // initial reading from sensor to begin a comparison
if(millis() - timer >= 1000) //trigger relay if sensor value is constant for greater than 1 sec
The paren in front of digitalRead(), and the one before the ; are not needed.
No. The two digitalRead()s will happen very close together. They are unlikely to ever be different.
Look at the state change detection example. It shows, properly, how to detect a state change.
Once the state change has been detected, not before then, record when that happened.
Periodically (on every pass through loop()), see if it has been too long since a state change happened.
I found the state change detection example and copycatted it a bit…I still struggle at combining a timer with the state change…On the serial monitor I can keep a count as I trigger the sensor but wanting to trigger a relay if the state does not change after 1 sec…
here’s where I’m at - Thanks Eric
int ledPin = 13; // the pin that the LED is attached
int sensorcounter = 0; // counter for the sensor
int currentstate = 0; // current state of the sensor
int laststate = 0; // previous state of the sensor
// initialize the sensor as a input:
pinMode(relayPin, OUTPUT); //relay output
// initialize serial communication:
// read the initial state of sensor
currentstate = digitalRead(sensePin);
// compare the currentstate to its previous state
if (currentstate != laststate) {
// if the state has changed, increment the counter
if (currentstate == HIGH) {
// if the current state is HIGH then the sensor
// went from low to high:
sensorcounter++;
Serial.print("number of button pushes: ");
Serial.println(sensorcounter);
if(currentstate != laststate && millis() - timer < 1000) // 1000 = 1 second
digitalWrite(ledPin, HIGH);
laststate = currentstate;
Unconditionally setting the start time is wrong. Set this (and it needs to be a global variable) only when the transition to pressed occurs. And, timer is a lousy name. startTime would be better.
lastState needs to be set to currentState on EVERY pass through loop().
Thanks for responding Paul...If it's not too much trouble could you help me with the coding...I really am stuck...I'll change the name of the timer too!!
This code should turn the LED on when the switch becomes pressed, and turn it off one second later, regardless of how long you hold the switch.
unsigned long startTime = 0;
startTime = millis();
if(startTime > 0 && millis() - startTime < 1000)
digitalWrite(ledPin, LOW);
startTime = 0;
Got the code working with my geartooth sensor…after 1 second of the sensor not changing state a LED (soon to be relay) is triggered…
Thanks for your help on my first project on an Arduino
Thanks Again! I learned a lot!!!
Eric
Here’s the sketch that I settled on:
//sorry if my format isn't perfect...My first project
int relayPin =13; //coil of micro relay to cut power
int oldvalue = 0; //previous sensor state
int newvalue = 0; //current state of sensor
unsigned long valuechangetime; //timer
void setup(){
newvalue = digitalRead(sensePin); //read current state of sensor
if (newvalue != oldvalue)
valuechangetime=millis();
oldvalue=newvalue;
else if (millis() - valuechangetime > 1000)
