I'm trying to use random() to generate a random pattern on an LED display. But I am either getting one random pattern that never changes, or it will be constantly changing. I am trying to only generate one random pattern every time display4 advances one digit. Hopefully if you look at this code it will make sense. In this version it is generating constantly changing random patterns.
Any hints or help would be greatly appreciated.
Thanks, Nick
#include <Wire.h> // Enable this line if using Arduino Uno, Mega, etc.
//#include <TinyWireM.h> // Enable this line if using Adafruit Trinket, Gemma, etc.
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_BicolorMatrix matrix3 = Adafruit_BicolorMatrix();
long previousMillis = 0; // last time a change happened
long interval = 200;
int display4 = 1; // 2nd bi color display
#ifndef __AVR_ATtiny85__
Serial.println("7 Segment Backpack Test");
#endif
matrix3.begin(0x73);
//int rP = 50;
if ( (currentMillis - previousMillis > interval) && (display4 < 5) )
display4 = display4 + 1;
if ( (currentMillis - previousMillis > interval) && (display4 > 5) )
// display1 = 1;
// rP == random(128); // I need this random number to change
if (display4 >= 4) {
display4 = 1;
if (display4 == 1)
matrix3.clear(); // clear display
matrix3.drawPixel(random(8), random(8), LED_GREEN); // I don't want constant random numbers, just one per count
matrix3.writeDisplay(); // write the changes we just made to the display
if (display4 == 2)
matrix3.drawPixel(random(8), random(8), LED_YELLOW);
if (display4 == 3)
matrix3.drawPixel(random(8), random(8), LED_RED);
if (display4 == 4)
Wow that worked. I could have sworn I tried your suggestion, but I guess I didn't. But that works so thanks for the help. I'm putting the code below. I ended up using two variables so I could get a different x and y axis number.
What up Holmes4. I thought I formatted my code correctly. Is there something else I have to do?
Thanks, Nick
int rP1 = 1; // this will be a randomly generated number
int rP2 = 1;
#endif
//int rP = 50;
rP1 = random(8);
rP2 = random(8);
// display1 = 1;
display4 = 1;
rP1 = random(8);
if (display4 == 1)
matrix3.drawPixel(rP1, rP2, LED_GREEN); // I don't want constant random numbers, just one per count
if (display4 == 2)
matrix3.drawPixel(rP1, rP2, LED_YELLOW);
if (display4 == 3)
matrix3.drawPixel(rP1, rP2, LED_RED);
if (display4 == 4)
//int rP = 50;
// display1 = 1;
display4 = 1;
changePixel();
void changePixel(){
if (display4 == 1)
if (display4 == 2)
if (display4 == 3)
if (display4 == 4)
I put your code to change a pixel in a function of it's own (a very good way to use functions by the way) can you see why your display was changing so fast?
