I can't understand why I keep getting 0.00 from this line:
"float val = sensorValue * (5/1023);"
The prints ok but the float is always 0.00
int sensorPin = A0; // select the input pin for the potentiometer
// select the pin for the LED
int sensorValue = 0; // variable to store the value coming from the sensor
// read the value from the sensor:
sensorValue = analogRead(sensorPin);
Serial.println(sensorValue);
sensorValue = sensorValue;
Serial.print(val);
Serial.println(" volts");
westfw,
Thanks, I found the answer in a sketch I found in my files. I ran a similar program and it worked
with this line:
"float voltage = sensorValue * (5.0 / 1023.0);"
Apparently only one of the two values need to be a float for the result to be a float.
Thanks for the reply.
